TV Combos
Problem for TV Combos
Generic problem for all TV Combos
HOrizontal width problem
By hattonhall26 on Oct 17, 2007
This Akai unit is a wide screen analogue CTV/DVD combo made in Turkey. Akai made a real booboo with on/off switch for the DVD player which is on an improperly supported PCB screwed into the front panel. The on-off switch is on part of the pcb which extends beyond  the support screws. As a result it is only a matter of time before a user pushes the DVD open/close button just a bit too hard and either bends the PCB or breaks it completely so that it is impossible to use the DVD player!............Good one Akai!
On the unit I have been given the picture raster is about 7 cm in from each side of the screen. The vertical size is normal. My question is, do you know if on this model, the screen display size (width)is selectable usuing  the remote control (which I do not have), as it is on most DVD players- but in this case in TV mode -or is this a real Horizontal width problem, perhaps the Hor O/P transistor BU2525AF or other width control component/s faulty etc.which must first be fixed?
Trying to find any info on the web about this Akai model number has proved futile and the Akai website is a joke...simply a Sales medium with no user support!
Solution #1
posted on Oct 17, 2007
Somewhat Helpful)
fixyaupman
Rank: Apprentice
Rating: 60%, 3 votes
With older sets i found dust as the main culprit in simmular situations.check for any  adjustment pot on the circiut controlling the screen width[normaly 3 pots close together open back of set to reveal electronic's]. be very carefull not being electrified as the set must be in operation while doing the adjustment.even turning the pot forward and back and then to the original position sometimes solve the problem.
Was this helpful?
Yes
No
Popular Solutions for TV Combos
Questions and Unsolved Problems for TV Combos
Answer
need 4 digit code for a magnavox-SDTV
Answer
I put in a dvd and it makes a clattering noise, I open it and the disc is spinning. Help!
Answer
Picture and sound gone tv bought for Christmas last year!!!!
Answer
I own a sony 42 HD LCD tv. It now has several small blueish dots in the middle of the screen. How do... (More)
Answer
the picture is all green shaded. DVD works fine in perfect color.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For TV Combos:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
