Error e2 in videocon V-NA 45 FDx Fully automatic top loading washing machine
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 02, 2011
E5 error on Videocon washing machine how to solve
E 5 ERROR IN VIDEOCON TOP LOAD WASHING MACHINE DRAIN SYSTEM IS ALL READY CLEANED
Sep 22, 2017 | Washing Machines
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
Apr 09, 2014 | Samsung SW62ASP Top Load Washer
My lg washing mechine error code EP
Write your answer...my lg top load washer displayed EP or E2 error codes and washer is not working
Jan 30, 2014 | LG WFT1071TP Top Load Washer
My videocon fully automatic washing machine (45FDx) is 7 years old. It is continuously showing E2 error. I have called the company technician but not of much use. Can u help pleae?
This can be due to a error in the control panel, You can switch off, remove the front panel and check for moisture on the panel, if so use a dryer to ward off the moisture. Also check the connections on the board. If the fault reoccurs then you might need to replace the panel board.Make sure the door switch, inlet valve and drains are clean.
Feb 12, 2013 | Washing Machines
Videocon washing machine model V NA-811 fully automatic body is rusted i would like to have a new body . where can i get it please inform me
Hi I have a Videocon V NA 811, don't know where to put the detergent and what is that small compartment with a net for
Nov 20, 2011 | Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
Aug 02, 2011 | Washing Machines
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
Jul 04, 2008 | Haier XQB60-91AF Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
