Question about Cambridge Audio Azur 640P Amplifier
Cambridge Audio A5 AMP - Unit will not turn on.
The amp has stopped working since un-plugging it and moving it to a different location (not bumped or dropped). When your press the power button you can hear the hum of power getting to the unit, however the on light does not come on and the unit does not function. I have checked the fuse that is obvious just inside the housing and it appears to be intact. I believe this has happened temporarily to the unit before, however now it seems to be permanent.
What is the problem likely to be?
Many Thanks in advance.
  • 104 Answers
I had the same problem with a tv a while back , the tech told me it was a dry and brittle circuit board they are ok until you move them and then they can sometimes crack a circuit , so my advice is get it fixed and then dont move it if you can help it
Posted on May 23, 2009
My Cambridge audio A5 amp has no power why?
The most common causes are in order a blown fuse, perhaps caused by a faulty output stage. Transformer faults. Other power supply faults. Have a look inside you might seen the part that has gone!
Aug 07, 2014 | Audio Players & Recorders
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
Cambridge azur amp 640a working brill till yesterday !! now protection light !!!! turned it off numerous time etc plenty of venterlation carnt get it to work
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Dec 08, 2010 | Cambridge Audio Azur 640A Amplifier
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Jul 21, 2009 | Audio Players & Recorders
Cambridge 640 amp, levels coming out r and l are different
Adjust "Balance" to center. If at center, something more serious in amp.
Paul
Jun 07, 2009 | Cambridge Audio Azur 640A Amplifier
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
Cambridge Audio Azur 640P Amplifier Logo
474 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
