Rca lab 1200
This started happening recently, I was listening to an album (33.3) when all of a sudden it switched into 45 mode on its own, then half a minute later switched back to 33.3 mode. Then, later on, it went to like a 42-ish speed (because I could still switch to 45 mode and tell a difference in the music. Now, it's stuck in 45 mode all the time. How did it get this way, and what can I do to get it working properly again? Another intermittent problem I've been having is that sometimes when I press Play it will set the needle down at the beginning of the record, then a split second later stop itself, like the stop mechanism was misaligned or something.
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Speed increased +3rpm every half second
You have drive issues. There is no easy way to fix or to isolate the problem. You'll have to take it to a service technician who can test your unit, and fix the problem. Usually it's one of the 3 main IC (integrated circuits) which cause this problem.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Posted on Nov 04, 2008
SOURCE: 33 1/3 records suddenly started to play too slow
It's most likely a belt issue. I'd call Crosley - their customer service team is there 24/7 and the number is 1-866-CROSLEY (or 1-866-276-7539). If you've had the unit less than 30 days, they'll flat out replace it. If it's been more than 30 days but under a year, they'll replace it and (from what I was told when I called about my own) it's $20 shipping but they'll cover any defects in workmanship, etc - as long as it's not accidental damage, blah blah blah.
But first - they'll hook you up with a Technician to call you back (before you worry about having it leave your possession for a while). The customer service people will take your info - they'll want model, serial, date of purchase, etc - and then depending on the time of day will connect you with, or have a Tech call you back at your convenience.
I was having the dreaded "Hello" error and a customer service rep actually told me how to get past it - I was thrilled :)
Daisy
Posted on Dec 08, 2010
  • 5370 Answers
SOURCE: When I turn on my Technics 1200 MK2 the 33 button
33 1/3 and 45 RPM Selector;---With these selector you have to choose the playing speed of the platter. Most 12" vinyl records with 1 track need 45 RPM, all others 33 1/3. Although this is no hard rule you could use it as a general guideline.----------
Pitch bend trick when on 33 1/3 RPM:---Some people use a little pitch-bending trick when the 33 1/3 RPM mode is selected. When a track is playing you can hold down the 33 1/3 RPM button and at the same time press the 45 RPM button. The speed will increase to 45 RPM but when you use it with tiny little pushes you can perform an un hearable positive pitch-bend.
------------------------Its quite possible that this buttons are getting jammed, they are not making proper contact.Try spraying contact cleaner spray directly to the side of the button and let it remain there, then press both 33 and 45 buttons few times and see if that makes any difference, but if that is not helping then,it sounds like a short on the pcb, one of the IC's could have gone bad, or the 33/45 have shorted out. -------- So its working on both 33 and 45 speed but not switching from 33 to 45 or from 45 to 33.-------- But first try freeing the 33 to 45 switch button.It must be getting jammed due to dirt or anything blocking it.---------- If that is not helping then try other things,---------- This will help.Thanks.Helpmech.
Posted on Aug 18, 2011
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Rca lab 1200
This is a belt drive turntable so it could be the belt slipping about. Before you remove the belt note where it fits.
Dec 25, 2013 | Audio Players & Recorders
My Sony PS-LX250H is all of the sudden playing too slow with a 33
Not sure what made it happen all of a sudden, but you might want to check out Mocamom1 's question related to PS-LX250H speed & the attached solutions. You may just need to adjust the SW screw on the underside of the unit (worked for mine that was playing everything at 35 1/4!)
Jun 27, 2009 | Sony PS-LX250H Turntable
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
Engine not starting
I would have to say its the starter switch, should be under dash on steering colume. they act like that, one day, or one week, or maybe a month, no problem, and then all of sudden it won't start. it will not thro any codes or make chk. engine light come on because its not a sensor, chg. the switch.
Feb 02, 2009 | 2004 Dodge Caravan
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Slider disaster
I have exactly the same problem. Can somebody help?
Nov 28, 2007 | iRiver H10 MP3 Player
43 people viewed this question
 Grubhead
Grubhead
