Question about Ecoquest Living Air Classic Air Purifier
Aquaguard classic orange light
When turned on, the green light wont turn on and the orange light is glowing continuously. When i hold down the music button while turning on the power button on the unit, the water flows out with the beep sound along with the orange and green lights blinking.
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: When pressing the power button,
Possible that the RCI is triggered by a false sensing or the sensor is falsely switching ON the fan as it get s a wrong signal .
It will be good to revisit the areas you have done the work and put back the old RCI . Now make sure the connections from this goes on to the controller unit and there is no faulty connectors.
If the ionizing is correct it must work , so the chance of the controller unit needs a check to see if the output is switched at random..
Posted on Dec 14, 2010
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
Red light blinking with beep in aquaguard classic
Do Press water start button on_off, for 2time and keep that in off conditions. Now start the machine.
Nov 08, 2011 | Ecoquest Living Air Classic Air Purifier
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
Honeywell htt 011 air filter light won't go off
Thank you to MPODHOLA. After cleaning your Honeywell HHT-011, if the red light does not turn off locate the very small button under the red light. As suggested use a paperclip, hold the button for 5 seconds and this resets the system. Make sure the unit is on when you hold down the button. I tried it with the unit off and it did not work. Turned on the unit, held down the button for 5 seconds and the system reset. No more red light.
Dec 03, 2010 | Honeywell HHT-011 Air Purifier
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 28, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
Nov 19, 2010 | Filter Queen Defender Air Purifier
How to reset hrv filter light
1: Press the clip_image001.jpg button to turn off the screen.
2: Press and hold the down arrow button until an 02 appears in the Roof Temp, when you see the 02 appear remove your finger.
3: Using the clip_image001.jpg button - short continuous pushes until you see 02 on the top (Roof Temp) and 5 underneath (House Temp) NB: The light should go off.
4: Press the clip_image002.jpg and this will save your changes.
Oct 25, 2010 | Air Purifiers
Replace air filter warning light to reset?
Sep 30, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
Ecoquest Living Air Classic Air Purifier Logo
91 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
