Question about Uniden TRU8885-3HS Digital Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
WHILE TALKING ON PHONES, IHUNG UP AND HAVE'NT BEEN ABLE TO ANSWER SINCE. I GET INCOMING RINGS, BUT UNABLE TO ANSWER ANY OF THE PHONES. UNABLE TO GET DIAL TONE.
  • 4 more comments
  • Anonymous Feb 21, 2008
    ISSUE WITH THE PHONE IS SAME AS ABOVE BUT DISPLAYS OUT OF RANGE.
  • Anonymous Mar 21, 2008
    new phone does not detect base
  • bearnmind Apr 20, 2008
    Phone rings, try to answer, phone shows connecting and then unavailable
  • Anonymous Mar 14, 2014
    my uniden phone wont ring when dialed
    phone will ring, and leave msg
    cannot dial out, msg is CONNECTING but does'nt
  • Anonymous Mar 29, 2014
    Want to turn incoming ring tone from off to on
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
Why am I unable to answer my phone?
Unable to answer calls - Support forum
https://talk.sonymobile.com/.../Unable-to-answer.../839311
Sony Mobile
Solved: Hi, my Z3 compact has been working fine but this evening I suddenly ... Thephone rings out but the swipe icons for answering the call simply don't ...
Unable to answer phone - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Droid Incredible
Oct 24, 2010 - 8 posts - ‎6 authors
I am unable to slide the "answer bar" across the screen, to. ... I'm trying to determine if this is a hardware problem with my phone of if it is a ... Why am I unable to answer calls on my Galaxy Exhibit ...
Mar 30, 2015
Can't answer incoming calls...
Jul 24, 2014
Galaxy S5: Slide to answer problem
May 11, 2014
Cannot answer phone calls
Mar 7, 2013
More results from forums.androidcentral.com
Jan 01, 2016 | Cell Phones
How to extend the incoming rings please
Go to Settings and choose options of Ring before Answering Machine.
Aug 17, 2014 | Uniden DECT 6.0 Cordless Phone ID
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
The phone rings but I am unable to answer. I
if your unable to answer the phone, just hang up and wait for another incoming call or press the power button
Oct 13, 2009 | Google Android
Inter-tel ECX 1000
You definitely can do this with a ECX feature set if you program the lines on the keys. You've got to program "Button Hopping" off in the system this automatically puts the first call on system hold when you press the line key for the second incoming call.
I don't think there's a limit to how many you can have on hold.
Oct 23, 2008 | Inter-Tel Encore Phone
Rings only 3 times then message
I did not see what model uniden phone you have. check here for a manual http://www.uniden.com/index/manuals_results.cfm?cat=1
Feb 15, 2008 | Uniden Cordless Phone
Two incoming calls issues
What type of phone system do you have?
Dec 19, 2007 | Lands Phones
Lands Phones Logo
867 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
