Question about Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL
Don't know how to use the ten-tap programmable switch
Don't know how to change the light (high/low/strobe) program. Didn't get any instructions from manufacture.
    Scholar:
  • 114 Answers
The Instructions are here:
http://www.streamlight.com/static/document/product_instructions/protac-hl_op_inst.pdf
Posted on Dec 25, 2013
  • Russell Neely
    Russell Neely Dec 26, 2013
    Thank you. It's nice to know where to go with my problems. I will show this site to all my friends.
  • mspennyg Dec 26, 2013
    Google EVERYTHING.
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
How to program the ten-tap" programmable switch.
Hi, I have placed a link to the instructions for the ten-tap programming.
Dec 25, 2013 | Streamlight Protac HL Flashlight, 600...
How do I use the ten-tap programmable switch
Hi, I have included a link to the instructions for the ten-tap programming.
How do I switch from strobe to constant light?
Depress the switch until light goes on but does not click on and then release just a little and depress again, light should switch to solid if it does than depress button all the way until it clicks on. If there is a high and low setting on the torch than make sure you are in high.
May 07, 2013 | Stanley 5 Watt Led Waterproof Rechargeable...
Need help 2001 chev cavalier running lights work but low &high bean lts don't
Someone will need to check for voltage at the dimmer switch and then trace back to the fuse box as needed.
Dec 12, 2012 | 2001 Chevrolet Cavalier
My high beam lights work but my lo beam lights don't,can you help me
When you switch from High to Low beams, do the lights go out, or continue, in the "High" beam position??? If they go go, the transfer switch, that changes the high/low beam mode is working. The most likely problem, is that the Low Beam filaments are both burned out. Some, on original equipment, never changed, can burn out within days/weeks of each other. Could be that.
Sep 01, 2011 | 2004 Kia Sorento
I hope I am stating my problem clearly: I just purchased a Woods 59377 indoor timer that I'm about ready to return to the place I purchased it because of the manual override button. What I didn't...
I have 59377 timer in my office.
Here is copy of manual:
http://waterheatertimer.org/pdf/Woods-59377.pdf
What job do want the timer to do?
It sounds like you want a programmable timer at night, and simple on-off switch at day.
Add a comment if answer below misses the mark.
YES, the manual override can be used as on-off switch.
Press manual override until Manual ON or Manual OFF display.
The manual override button has 4 states:
Auto ON, turns lamp ON immediately and programming resumes at next set time.
Auto OFF, turns lamp OFF immediately and programming resumes at next set time.
Manual ON to choose permanent ON.
Manual OFF to choose permanently OFF.
Aug 26, 2011 | Woods 7 Day Digital Heavy Duty Timer...
My headlights went out dont know what the problem is low beam dont work high beams works
it may be the dimmer switch located on the base of the steering colume that is not working on the low beam side.also the headlights themselves may need changing if the low beam filament is burnt out and you didn`t realize one was burnt out then the other one burnt out.if that`s not the case then it could be a bad connection at the plug connector for the low beam or for some reason power is lost between the switch and the headlight.you don`t say if this has day time running lights,if it does then it could be the drl relay that is bad.
Apr 21, 2011 | Chevrolet Blazer Cars & Trucks
Fuse diagram for 91 chevy corsica
Need copy of wiring schematic for 1991 chevy corsica
Dec 10, 2008 | 1991 Chevrolet Corsica
Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL Logo
246 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
