Question about Toro& Electric String Trimmer
Toro electric weedeater
Smoking at the base and smells funny
  • artbreak May 17, 2009
    Thanks!
  • heyhoney May 24, 2009
    How do you change the bearing in the head? I have the same problem.
  • 163 Answers
Your bearing in the head is going bad. Don't use or it will damage more componets. You need to replace. Hope this helps.
Posted on May 17, 2009
  • May 17, 2009
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Mower started to smoke then shutt off
did you tip it on its side to do the belt? does the oil smell like gas like the needle valve in the carb is not sealing
Apr 19, 2012 | Toro Lawn Mower With Toro Power Tools
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Smoke coming through air vents
Is it smoke? Or is it steam? If it's really smoke, it will smell like burning wires and you have an electrical short somewhere. You're going to have a fire unless it's fixed.
My guess is that it's probably not smoke or you would have already had a fire.
With that said I'm going to say that it's steam in which case your heater core (which is a small radiator located under the dash) is leaking coolant and the resulting steam is rising through the vents. The steam will have a sort of sweet and yes, a steamy smell to it. It will also leave a funny film from the radiator coolant coating the inside of the windshield.
The heater core should be replaced if my assumptions are correct.
Dec 27, 2010 | 2000 Dodge Neon
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
My oven keeps switching off, and it doesnt come back on until I turn the temarature up. Its almost as if it is over heating
your power cables might be loose on the electrical board, turn off breaker to oven, open it up and verify the wires from the wall are tightly connected to ther posts on the electrical board. If you smell a funny smoke or weir smoke it is electrical problem and shut it off immediately at the breaker box...Cal a repair guy if you don't have to call the fire department.
Oct 13, 2009 | Tecnik TKC8525 Double Oven
99 cavalier Smoke coming out from under dashboard!
now this may be a long shot... but i had a similar problem on my cutlass. but it wasnt wiring...... it was from the tube running from the head of my engine...... the smell and smoke were coming from hot oil coming out of the crank case vent tube and then being sucked into the air inlet for the heater/ ac.
since a electrical wire's protective cover is petroleum based as is oil.... they smell very similar
Jan 08, 2009 | 1999 Chevrolet Cavalier
Toro& Electric String Trimmer Logo
648 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
