Question about Frigidaire Dishwashers
My Frigidaire FDB2310LCC2 will not start. no power /lights on front panel
My Frigidaire FDB2310LCC2 will not start. When I close the door, it is latching. But when i push any panel buttons - normal wash, start...nothing happens - no lights, no time left display...The circuit breaker downstairs is on and works. In the service data sheet it says replace console assembly, replace door switch, replace control board... Gee I haven't checked my wires coming in but the connections have worked for the past 4 years
SOURCE: Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Posted on Nov 24, 2007
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 1003 Answers
SOURCE: FDB768GCC0 model Frigidaire Gallery series Dishwasher
REPLACE TIMER
Posted on Jan 18, 2008
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
SOURCE: model mdb7601awb diswasher . Nothing
I have had the board replaced 5 times and the entire dishwasher replaced once. It was necessary to go to the state attorney general to get Maytag to extend the warranty. Just called the service center for the sixth time, after this the warranty will be gone and will replace with something well built.
Posted on Oct 23, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Get my frigidaire washer to start. The lights go on as soon as I close it. Usually I have to push the start button for this to happen.
Hello friend, thanks for your post!
It sounds like it could be a possible issue within your control panel or door lock assembly. If the door is not making that connection it is closed the washer will not start. I would recommend having a professional come out to properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
Sep 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Lights will come on and timer will count down but the washer will not begin
Hello -
Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 23, 2012 | Frigidaire GLTF2940ES Front Load Washer
FRIDIDAIRE GLTF2070DS0
Hello - Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader will not turn on
Sep 24, 2012 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frs26r4a after opening and closing freezer door all panel lights are on - both cube and crushed ice panel indicators, and the light that illuminates the water and ice dispenser remains on until...
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Dec 25, 2010 | Frigidaire FRS26R4A Side by Side...
I have a model FDB2310LCC2 dishwasher and it won't turn on. The column cycle lights washing cleaning drying and sanitizing are all blinking simultaneously along with the "high temp wash" light. I...
This may be a problem with the door interlock switches. You will need to shut off power to the dishwasher, unscrew the control panel and remove the wires to the door switch ( make note of where the wires go on the switches) and check the switches with an ohm meter ( do this with the door closed, the switches should show good continuity). repost if any questions.
Jul 11, 2010 | Dishwashers
FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 | Dishwashers
Dishwashers Logo
138 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
