Question about Tablets & eReaders
Where do I put micro sd card in for my proscan plt7223g
I just want to know where to put the micro sd card. The instructions are clear enough in the booklet given with the tablet. Where it says to put it, it appears to be where it says it is they HDMI.
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
Posted on May 14, 2008
SOURCE: micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Posted on Nov 04, 2012
  • 22 Answers
SOURCE: have an android tablet but have lost an inside SD
Well their is plently of websites out their that you can download "flashes" like the software, http://www.redmondpie.com/download-and-install-android-2.3.6-gingerbread-grk39f-on-nexus-one-how-to-tutorial/ this is a good website for getting the software depending on what version of android you have and then tells you how to do it incase you dont know.
Thanks
Posted on Aug 06, 2013
www_dahmani
  • 49 Answers
SOURCE: I have a proscan PLT7223g tablet and trying to
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
Posted on Jan 16, 2014
sschoemann
  • 150 Answers
SOURCE: yarvik manuals
how are you using the card? you need to move the software that you can to the card and set it to be run from there. you also need to clean your tablet regularly, just like a laptop. not shutting apps down properly will leave your system full of garbage and no room for anything. this is true for ALL tablets
Posted on Sep 05, 2014
How do I transfer from nand to sd
Hi
If your SD card is not recognised there are possibilities:
1. The manual - I'l give the link later in case yours is mislaid - only mentions "Micro SD" up to 32Gb. Sometimes these cards can be the SDHC category and these are not always accepted in devices designed for SD only. They look identical so make sure yours doesn't say SDHC.
2. The file format on the card can be significant. It needs to be a format compatible with the phone. If you have no other data on the card, it might be easiest to see if the phone will format it.
3. Of course it might be a faulty card - can you test it elsewhere?
The link for the manual mentioned above is here:
Proscan Media Tablets eBooks ReadersInstructions Manuals Quick Start...
Its about 15th down the list and will download direct to your computer.
With regard to downloading from nand to SD card, is this essential? If you have a micro USB to normal USB, then you should be able to use a computer to take data from the nand. The nand would show up as a drive in "My Computer".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Have available space on the nand flash but cannot down updates
To clear a "glitch", sometimes you have to factory reset it.
YouTube has a video at the following link .....
https://www.youtube.com/watch?v=npnIdZgXJcA
Dec 10, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
I have a proscan PLT7223g tablet and trying to download app from goolge play store and I'm getting error code 911 What is this and how do I fix it
Jan 16, 2014 | Tablets & eReaders
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
