Question about Casio Wk500 Wk-500 Keyboard Workstation Hear It Now New
Casio Wk500 Wk-500 Keyboard volume control don't work
  • 411 Answers
SOURCE: SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Posted on Jun 19, 2009
  • 5603 Answers
SOURCE: I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Posted on Aug 24, 2009
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
  • 298 Answers
SOURCE: How do you replace the adaptor jack on a Casio
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Posted on Feb 02, 2011
Testimonial: "Thanx, I found this most helpful"
  • 5603 Answers
SOURCE: Where can I get a replacement power
Here is one:
http://www.amazon.com/Casio-AD-12MLA-Adapter-Power-Supply/dp/B00029HDT0
and another, less expensive on Ebay:
http://cgi.ebay.com/Genuine-AD-12MLA-12V-2-5A-2500mA-AC-PowerSupply-ADAPTER-/390280683299?pt=LH_DefaultDomain_0&hash=item5ade8a9f23
Posted on Feb 25, 2011
Testimonial: "Many thanks - am in UK but was able to find similar item here."
I replaced sustain pedal jack...now sustain is on ALL the time, even with pedal unplugged
When you replaced it, you either have the wrong jack, wired it wrong or it is shorted out where you connected it. Recheck the connections.
Dec 18, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
Correct adapter for casio wk 500
Casio AD-12 for my country with 240V
You may use any 12V 1A AC Adaptor that has the same DC jack provided the center is NEGATIVE. Most common generic AC Adaptors are Centre POSITIVE.
So cut DC end of the wire and solder them in reverse and insulate with tape and it will work.
Jan 20, 2014 | Casio Lighted Keyboard LK90STADMC
Factory settings
With IDES4, I can load factory defaults to my WK8000.
WK500 uses DATA MANAGER 5.0. If I am not mistaken, you can only save/restore/delete "user data" from and to the instrument.
FACTORY Settings are always unchanged in the instrument and it reset itself every time you power cycle.
Jan 15, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
It wont power up
Do You use original CASIO power adapter for this keyboard?
Some CASIO (CTK-5000) models require inverse voltage polarity than most of others adapters have!!! RISC OF BURNING OUT ELECTRONICS!!!
Dec 09, 2012 | Casio Wk500 Wk-500 Keyboard Workstation...
I want to record from my wk 500 to my imac
You have to get a cable that runs from the 1/4 inch headphone jack on your keyboard to the 1/8 inch line in on the back of your iMac.
Jul 01, 2011 | Casio Wk500 Wk-500 Keyboard Workstation...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Oct 22, 2009 | Music
Aug 12, 2009 | Casio Music
No.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Casio Wk500 Wk-500 Keyboard Workstation Hear It Now New Logo
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
