Question about Nokia 1600 Cellular Phone
Nokia 1600 light ic jumper
Lcd light display
4 Suggested Answers
sukkur101
SOURCE: nokia 1600 problem
try the below given jumper settings,it is applicable only if the board print is available
Posted on Aug 28, 2008
JAN_yuanjia
  • 470 Answers
SOURCE: nokia n70 whitedisplay
the display ic is of nd the LCd is ok,  so checjk the crysta l iC  o the flash,, i conclude maybe the crystal IC has the problem
Posted on Apr 26, 2009
SOURCE: light ic
nokia 1100 pfo jumper
Posted on Dec 30, 2010
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
Backlight burned out, how do I replace it?
The back light is typically an integral part of the LCD display, so you may have to replace the entire display. On some displays, the touchscreen and back light connections are separate from the display and on some displays, these connections are soldered to the LCD display. Trying to take apart the LCD display just to change the back light can result in breaking the LCD display. You are better off just replacing the entire display if you can find it for that model.
Oct 15, 2013 | Garmin GPSMAP 176C GPS Receiver
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
My nokia 6300 is all the lights i.e. display and keypads lights the are working the display has become black and white can u give me some instructions
Hello your problem is not relating to Lights,but possible problem comes from the failure of LCD/LCD socket/ Display IC (filter).So, to solve this you can at least open the case and clean the components/board near the display socket Or Re-insert the LCD.If this trick doesn't helps contact nearest mobile repairing shop.Good luck
Jul 22, 2012 | Nokia 6300 Cellular Phone
No screen display after incert my fist password digit
its usually happen at k850i.the problem actually from display light on lcd are not lighting. if you have experience in phone you can make a jumper wire to reconnect light line between lcd and PCB(engine).but usually the fastest way are change the lcd phone.simple but need money.may it help.
May 25, 2010 | Sony Ericsson K850i Mobile Phone
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
Apr 01, 2010 | Panasonic NN-T551 Microwave Oven
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
LCD's won't power up
The LCD not displaying a picture may just have a back-light issue. You can verify this by turning on the display, taking a flashlight and pointing it at the LCD then looking at the area that is illuminated on an angle and up close (1" - 2"). If the picture is visible then it is a back-light. You either need an LCD back-light inverter or the back-light itself.
Nov 08, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
L6 display
THIS PROB IS USUALLY AT THE LCD CONNECTOR. SO CHEQUE THE CONNECTOR ON LCD AND PBA. CLEAN IT N CONNECT,MIGHT WORK
Sep 26, 2007 | Motorola Mobility L6 Cellular Phone
Nokia 1600 Cellular Phone Logo
553 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
