H line CTV START PICTURE OK BUT SUME TIME SHOW H LINE
    Habit-Forming:
  • 47 Answers
Your H line or Horizontal line is caused by a loss of vertical drive. As intermittent as you have, probably bad solder joint at the vertical drive IC. If you have no experience in soldering, then my recommendation is to have it professionally repaired.
Posted on Dec 27, 2013
4 Suggested Answers
  • 277 Answers
SOURCE: My picture is black except for a thin horizontal line
hi When you let the line to long it will burn in!! you need to look into the VERTICAL output section. Most notably check the solder joints on the vert output IC and ESR the caps. If you don't know what any of that means, then take it to a professional. good luck
Posted on Feb 26, 2006
randy_coloma
SOURCE: tv show vertical line
change vertical IC
Posted on Dec 18, 2012
  • 27 Answers
SOURCE: Sansui B2B 21v ctv.my ctv working is good,but
Its seems to me you have faulty capacitors on the boards (it can be see if capacitor are bigger than normal)
Posted on Nov 16, 2013
How to fix the vertical problem of the ctv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 28, 2015 | Sansui Televison & Video
Retresh line
There re so many reasons for the retrace lines appear on the screen. It will be best to contact any service technician in this case. Gopakumar Gopalan Google
May 19, 2014 | Samsung Televison & Video
Tv stays standby mode
There are a few possible reasons
1. Line scan has failed - line o/p transistor
2. Frame scan failed (unlikely)
3. Power supply problem/chopper transistor
4. (and hope it's this because all you need is a soldering iron, good lighting and soldering skill) Dry joints or cracks around line output stage
May 17, 2014 | Sharp CTV 21V-FW150M BLK
Sansui B2B 21v ctv.my ctv working is good,but recently no video, onely Horizontal line on the screen.
Nov 15, 2013 | Televison & Video
Toshiba 46xf355db upon start up there is a fuzy picture and lines
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
May 17, 2017 | Televison & Video
Kraus kitchen faucets
under the faucet wher the suply lines conect is a nut on ech line sume are small nuts but moste are large plastic whith wings for hand titening if it's the handel your talking about thers a allen head setscrew
Mar 08, 2012 | Delta Faucet Single-Handle Bath Faucet,...
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Jun 12, 2011 | JVC Televison & Video
Printer does not print. allplugs are ok
Dose the printer show up under printers and faxes? Dose it show the words ready or work off line under the printer? If the printer shows work off line, right click the printer and take the check away from work off line. It should change the wording to ready and start printing.
Nov 19, 2008 | HP Computers & Internet
Feb 20, 2006 | Hitachi 36CX39B 36" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
