Can I remove Java plug in from IE11 not just disable
  • Howard Hyman
    Howard Hyman Dec 27, 2013
    I have since solved the problem. It meant identifying all Java entries in Registry and deleting them. I have saved back up entries for now in my docs.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Yes, but you dont need to. Anyway, try to go the website that you got it on. They should have a way to get it off.
Posted on Dec 25, 2013
How do I disable password helper? I did not install it, but it is in my Manage Add-Ons and is enabled. The disable box is grayed out so I can't click on it and I went to the Control Panel and Progra
If you type control panel into the start search box, select control panel and find add and remove programmes. Scroll down and remove password helper.
Oct 12, 2014 | Computers & Internet
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    Vtdeo play from internet never smooth
    I had the same problem, but with a different ISP. It is not the ISP but, perhaps, the version of IE you are running. If you are running IE11, then you need to uninstall it, and go back to IE10, or run Firefox ( I don't like Firefox, but it is a solution). If you need help on uninstalling IE11, let me know. Also, go to http://support.microsoft.com/fixit/
    Click on Windows Media Player, and click on the problems you are having, and Fixya will fix them automatically.
    Apr 01, 2014 | HP Pavilion 764n (DA194A#ABA) PC Desktop
    Streaming video freezes
    update flash player or instal flash player also update java.
    Minimum Recommended Internet Browser** Respondus Lockdown Browser and IE11, Microsoft Edge, Safari , Chrome or Firefox Respondus Lockdown Browser and Firefox Java Java is required to use Blackboard. Visit our Java support page for information about troubleshooting Java. if you have java remove it and then install new download, uninstall and shut down and restart the pc. then instal the update from web page. flash player is recommended as it shortens down the video needs so it stops freezing up on slow connections. .
    Feb 16, 2018 | Toshiba Satellite L655-S5096 Notebook
    E2020 login keeps asking for java which is already installed
    You must be logged in as an administrator. If prompted for your administrator password after a command, enter it and then press the Return or Enter key.
    1. Open Terminal, located in the Utilities folder.
    2. Enter this command, then press the Return or Enter key:
      sudo mkdir -p /Library/Internet\ Plug-Ins/disabled
    3. Enter this command, then press the Return or Enter key:
      sudo mv /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin /Library/Internet\ Plug-Ins/disabled
    4. Enter this command, then press the Return or Enter key:
      sudo ln -sf /System/Library/Java/Support/Deploy.bundle/Contents/Resources/JavaPlugin2_NPAPI.plugin /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin
    5. To re-enable Java SE 6 Web Start, enter this command, then press the Return or Enter key:
      sudo ln -sf /System/Library/Frameworks/JavaVM.framework/Commands/javaws /usr/bin/javaws
    Additional Information The following steps will undo the above commands and restore Java 7.
    1. Disable Java SE 6 Web Start opening:
      • Enter this command, then press the Return or Enter key:
      • sudo ln -sf /System/Library/Frameworks/JavaVM.framework/Versions/Current/Commands/javaws /usr/bin/javaws
      • When prompted, enter your administrator password, then press the Return or Enter key.
    2. Re-enable the Java 7 applet plug-in bydownloading and reinstalling the latest version of Oracle Java 7 JRE.
    Important: Mention of third-party websites and products is for informational purposes only and constitutes neither an endorsement nor a recommendation. Apple assumes no responsibility with regard to the selection, performance or use of information or products found at third-party websites. Apple provides this only as a convenience to our users. Apple has not tested the information found on these sites and makes no representations regarding its accuracy or reliability. There are risks inherent in the use of any information or products found on the Internet, and Apple assumes no responsibility in this regard. Please understand that a third-party site is independent from Apple and that Apple has no control over the content on that website. Please contact the vendor for additional information.
    Apr 25, 2013 | Computers & Internet
    Says i don't have java
    What browser are you using? Due to some security issues, some browsers will disable the Java plug-in. This is often the case for older versions of Java. Check java.com for patches.
    Check if the plug-in is enabled. In Internet Explorer, click on the Gear in the menu bar and select Manage Add-ons (scroll down to check the Java plug-in). In Firefox, go to Tools > Add-ons. Then go to the Plug-ins section. For Chrome, navigate to chrome://plugins.
    If you see that Java is disabled, click on Enable and then restart the browser.
    I hope this helps.
    (due to the security issues with Java, you should only have one browser with the plug-in enabled. Do most of your web activities in a browser with Java disabled.)
    Mar 20, 2013 | Pogo.com Video Game Consoles & Games
    How do I go about downloading java script?
    Java script is native to all browsers. You may have it disabled. You will have to go into your browsers settings and enable java script within your browser. If you have any plugins such as "No Script" then you will need to disable them or uninstall them for Java script to work properly again.
    If you meant to ask how to download Java (it is different than java script) then you would visit http://www.java.com and download the software and install.
    Seeing as you posted this as a Facebook problem I would be satisfied to say that your problem is java script is disabled in your browser settings.
    Nov 07, 2011 | Facebook Social Network
    Not able to enable java on my vista home premium
    you can download java from here for Vista,
    http://www.java.com/en/download/manual.jsp
    Good Luck!
    Jun 23, 2009 | Microsoft Windows Vista Home Premium with...
    Heya I have problem for watching the vedios on youtube. I dont know how turn on the java ,and also have problem for installing the new version of adobe flash player.Dont know want to do. Can u help...
    dear donya, Internet Explorer 7 To enable or disable Java:
    1. From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
    2. Click the Programs tab.
    3. Click Manage Add-ons.
    4. Highlight Java Plug-in.
    5. Under "Settings", click Disable.
    6. Click OK, and then OK again.
    To enable or disable JavaScript:
    1. From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
      Click the Security tab.
    2. Click Custom Level... .
    3. Scroll to the "Scripting" section of the list. Click Disable or Enable.
    4. Close and restart your browser.
    Internet Explorer 6 and earlier
    1. From the Tools menu, choose Internet Options... .
      in version 6, click Custom Level... .
      • Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
        JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
    2. Close and restart your browser.
    download latest adobe flash player and install.
    if u r using ie6, try to upgrade it ie7.
    thanks,
    Sep 25, 2008 | Computers & Internet
    Java not enabled
    It would be helpful to know what internet browser you are using, but typically you can enable/disable Java in your internet options or preferences.
    For example:
    I am using Mozilla Firefox, so from the "Edit" menu I choose "Preferences". I then choose the "Content" tab. Under that tab is a checkbox specifically to enable/disable Java.
    I suspect that for Internet Explorer there will be a similar situation. I believe that it would be under the tools menu under options.
    Good luck,
    James
    Apr 28, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
