Question about Car Audio & Video
Scosche manual how do i get the pocket to hold on to the rest of the kit so it doesnt flop around under the radio on the gm2600
4 Suggested Answers
  • 330 Answers
SOURCE: Mannual Box, 1990 V6 4runner
Change the trans fluid, put a new filter and adjust the linkage
Posted on Jul 09, 2008
  • 13 Answers
SOURCE: Where can I find a
http://www.scosche.com/ecom/download/CBHSOL5_SglPg.pdf
Posted on Mar 17, 2011
  • 32 Answers
SOURCE: i had a tech install
You need to carefully remove the plastic trim from around the head unit. It should just snap off with your fingers. On the left and right sides of the head unit there will be thin slits made to slide in thin metal tools that come with your new head unit. If the installer did not give these to you, call him and ask for them. If he doesn't have them, most local car modification shops have dozens of these lying around, and will give them too you if you ask. Once you have the tools, it is as simple as sliding the tools on either side of the head unit at the same time until you hear the installation cage release. Then slide it out.
Posted on May 03, 2011
Scoshe ha1707dgb radio pocket is to small
The radio mounts from the back side of the kit using ISO mount screws. You cannot mount the radio using the metal sleeve as with most other installations. The instructions that came with the Scosche kit illustrate this method.
Feb 28, 2014 | Scosche Industries SCOSCHE HA1707DGB...
Heater in 2003 acura tl is blowing cold air
Check the coolant level,if its low there will not be enough coolant to enter in to the heater radiator,check for leaks too
Oct 15, 2013 | SCOSCHE Aa1574b 99-03 Acura Tl & 01-03 Cl...
What is a purge or vent solenoid
If it is on steady, It is a more serious (Problem) If it flashes on end off it is not that serious of a (Problem) But to find out the code ,A code reader will have to be hooked up to it,
Oct 31, 2012 | Scosche Industries 2002-05 Ford Explorer...
I need the wiring diagram of the stereo cassette radio am/fm, please help my radio is dead (positive and speakers terminals)
You're going to need a multimeter/voltmeter and a 9v battery to do this. It's easiest to first find your constant and switched/ignition wires.
For the constant, you can get ground from any piece of metal inside the dash, and begin touching all the wires, one at a time until you get a voltage. The meter should show 12v or just under. This is your constant. Do the same for the ignition/switched, but this time with the ignition on. Check the remaining wires until you get one at 12v or just under. To check now turn off ignition and the voltage should go away.
For the speakers, it's a little more guessing, but you can check them with a 9v battery. Start with any of the remaining wires and hold it on the positive terminal of your 9v battery. Now go through the remaining wires and touch them, one at a time, to the negative terminal. You should hear a pop from the speaker when you come across the pair. Note the colors and the speaker where it came from. Now move on to another wire and repeat.
You may come across a wire that will not pop when paired with any of the other wires. This could be your ground. Put it a side until you've figured out all the speaker wires. Now go back to the possible ground and use your multimeter to see if you get 12v with your constant wire on positive and the negative wire on the possible ground. If it does it's your ground. If not, it could be something like a dimmer, power antenna or remote line that isn't necessary in replacing a stereo.
The downfall of doing this is that it doesn't tell you polarity. After you finishing connecting the radio to the in-dash wiring turn it on. Listen to the sound carefully. If it sounds tinny one or more of the speakers polarity are incorrect. Try to determine which speaker/s sound tinny and reverse there wiring. Check again and hopefully everything's sounding good.
I hope this is helpful.
Ray
Mar 03, 2011 | Scosche Industries Scosche MN1377B 199902...
Will this work for a kenwood dnx6160 dvd reciever
Yes should work fine for the 6160.. if you have not bought the 6160 yet.. but a 6960!
Feb 03, 2011 | Scosche Industries Scosche Ma1543b Mazda 3...
My remote start and locks have poor range what is a good fix for this problem
Make sure the remote battery has good voltage. If the remote start has a single wire for the antenna, make sure it's as straight as possible. Your better systems have a black plastic antenna that is placed high on the windshield.
Sep 29, 2010 | Scosche Industries Scosche Gm1598b Iso Din...
Manual DV.-K285P required for elderly lady.
If this is for the Daewoo DV-K285P VCR, here is a manual for the DV-K280, it should be the same thing, or close enough:
http://tv.manualsonline.com/manuals/mfg/daewoo_electronics/dvk280_k480.html
Jul 12, 2010 | Scosche Industries Scosche Do2110b...
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS smas5305@yahoo.com thank you Thomas Anderson
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
