Question about GPS
GTM 36 antenna wiring diagram - GPS
2 Suggested Answers
SOURCE: Looking for a wiring diagram for a garmin gtm 20
Just so happens that my connector lost the red and purple wires, so the picture you have was a great help. Looking at the connector, the wire colors are red, purple, yellow, blue, black, green, brown.
Posted on Nov 08, 2012
Garmin nuvi 760 charging problem
The wire may be defective, especially where it plugs into the connectors.
Nov 25, 2013 | Garmin Nuvi 760 Car GPS Receiver
Garmin GTM 25 charger cord has broken wire inside.
Most likely that is the FM antenna lead that goes to the traffic receiver. It should only be connected on the end that goes to the receiver.
You say the GTM-25 is not charging. Is the fuse blown? The charger takes +12VDC from the lighter socket and supplies +5VDC to the GPS.
Dec 15, 2011 | Garmin GPS
I have a Garmin with a GTM 20 traffic receiver p/n 010-00544-13 and I wanted to know if there is a fuse that can be changed and how do you do it?
The GTM-12 is an antenna including FM receiver - there's no fuse in there. It's powered by the Garmin navigator not from an auxiliary power source.
Jul 01, 2011 | Garmin GTM 12 FM TMC Traffic Receiver...
My GTM 20 tip got unscrewed and the parts fell out. I put the parts together and then found out that both the car socket fuse and the GTM 20 fuse were busted. I replaced both fuses. The car socket works...
The GTM 20 can be repaired. It's likely that either you're not using the correct fuse or there's a short circuit. The short circuit would be caused by the metal tip, spring or fuse touching the outer part of the plug. There's a repair kit available from http://www.gpscity.com/garmin-replacement-parts-for-gtm2x.html
Jan 26, 2011 | Garmin GTM 20 Lifetime Traffic Receiver...
Looking for a wiring diagram for a garmin gtm 20 traffic receiver. A couple of wires pulled loose.
Aug 13, 2010 | Garmin GTM 20 Lifetime Traffic Receiver...
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Wiring diagram for pioneer premier deh-36
wiring for deh 3600????
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Aug 18, 2008 | Car Audio & Video
GPS Logo
185 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
