Question about Sunpentown SP-3619 3.6 Liter Hot Water Pot
Sunpentown hot water pot won't stop boiling - Sunpentown SP-3619 3.6 Liter Hot Water Pot
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Thermostat and unplug plug
Posted on Dec 28, 2013
Churchs bunn. Vps 04275-0013 started heating water till steam comes out fill hole. Causing water to drip everywhere....thinking a thermostate is not opening causing steam
Over Boiling or constant heating of tank water is an indication of a shorted thermostat (or out of calibration). Call your vendor for service. (especially if this equipment is on loan.)
*** the following is for information only. Repairs should be performed by a qualified Bunn Tech. ***
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
PS; There is a slight chance that your thermostat is set too high. There is a dial on the thermostat that can be turned counter clockwise to lower the temperature of the brewing water. Water should be about 190-205 F for coffee. Tea drinkers want 210 F which is too close to boiling point of water. If your in the mountains (+2000 feet) then the boiling temp will lower. Was it possible the brewer came from a low (sea level) location and moved to higher altitude? Then the setting is off and must be set lower (a fine adjustment). But note that if your on the top of a high mountain (like Haleakala, Hawaii) then it has to be set a lot lower and you will only get luke warm brews at 9,000 feet!. Adjust the knob clockwise to get it to boil. Then back it off counter-clockwise a bit till it stops boiling. Make another brew to check if the reheat comes to a boil but stops after a minute or so. It should not boil on longer than 2-3 mins. Back it off a bit more if it does. Brew again to check. If none of this works then you will need to replace the thermostat. If your at a really HIGH altitude location, then you will need a specially adapted high altitude brewer. Call your coffee vendor for advice.
Feb 16, 2018 | Coffee Makers & Espresso Machines
I cannot take off the lid of the Pro chef and manual is unclear. How do I unlatch it?
Manual Pro Chef PU 100
I have received the hot water boiler, but it does not stop boiling the water. Instead of going to "Keep Warm", the machine continues to boil the water indefinitely. We left the boiler on and came back after 2 hours, and it didn't stop heating the water. Therefore, I refilled the boiled, turned off the machine, unplugged it, plugged it back in, and then turned it back on. The water continues to boil without going to "Keep Warm". I require a solution to the issue or a replacement as soon as possible.
Apr 25, 2014 | Le Chef Electric Shabbos Hot Water...
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
How do you open an alessi pepper mill to refill it?
You will need:- Large cooking pot- Grinder- Tongs- Hot pads or oven mitts (mitts are recommended)- CautionPut the grinder into a large cooking pot. Fill the pot with water until the grinder is completely submerged. Make sure that the plastic parts of the grinder do not touch the bottom or sides of the pot. On the stove-top bring the water in the pot to a boil. Once the water is boiling turn off the heat. The grinder is now very hot and full of hot water so be careful not to burn yourself. Using tongs remove the grinder from the water and hold it upside down to drain most of the trapped water back into the pot. Now turn the grinder upright again to trap any remaining hot water. Using your hot pads or oven mitts grasp the glass part of the grinder in one hand and the plastic part with the other hand and pry them apart. Let both parts of the grinder dry completely then refill it and snap the plastic top back on. These make great grinders for other spices as well such as coriander. Enjoy!
Aug 09, 2011 | Coffee Makers & Espresso Machines
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Only a few months old and when we plug it in it starting making a squealing noise and only got hot water when it finished . Faberware Percolator.
Hi Sharon. ALL Farberware coffee pots make racket. You have a pot that is made in China. When the water is hot the noise stops and it goes into keepwarm mode. As long as your water is hot 175 to 185 it is good. If you were trying to make coffee and you are not perking through the basket is another case.When you want to make coffee you MUST use the cone spring in the pump.That keeps the pump tight so the hot water goes up the pump. With out it the water just boils and does not go through the pump. Good luck. and if you want more info use callahanronald@att.net Ron
Feb 04, 2010 | Faberware FCP412 Coffee Maker
Sunpentown SP-3000 Hot Water Pot Dispensing Button No Longer Work
http://www.eserviceinfo.com/download.php?fileid=30158
Basically all eletric hot water pots are the same just like frig/stove.
pdf with wiring and parts.
Enjoy.
Dec 22, 2009 | Sunpentown SP-3000 Electric Kettle
Wolfgang Puck 7 cup Rice cooker
THIS is a generic manual and can be a guide for most cookers/steamers.
The rice and water go into the Inner Pot, Not the steamer basket.
Some useful tips:
  1. How can I reduce or stop the rice from sticking to the bottom of the pan or browning excessively?
    • Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
    • Take care to use proper water to rice ratios.
  2. How can I stop the water in the inner pot from boiling over the lid?
    • You may be using too much water.
    • Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
  3. How can I clean my rice cooker?
    • Unplug and allow to cool completely.
    • Always exercise extreme caution as the unit becomes hot during operation.
    • Soak the inner pot in hot, soapy water for a few minutes.
    • Wash with a non-abrasive pad.
    • Wipe the heating base with a damp cloth.
    • All other items can be washed with soap and hot water.
    • NEVER use an abrasive cleaner or steel wool.
    • Note: This unit SHOULD NOT be put in the dishwasher,
  4. How does a rice cooker know when to ‘Keep Warm’?
    • The boiling temperature for water is 212°F.
    • As soon as all of the water has evaporated the temperature inside the inner pot immediately rises.
    • Rice cookers have a Keep Warm Setting that can detect when the temperature rises above the 212°F.
    • When this happens it automatically turns to the Keep Warm Setting.
    • This helps to ensure perfect rice every time.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 01, 2008 | Kitchen Appliances - Others
6 cup rice cooker
its very easy if you put 6 cups of rice= 6 cups of water
5 cups rice = 5 cups water ...equal proportion
Jan 06, 2008 | Rival RCS200 20-Cup Rice Cooker
Sunpentown SP-3619 3.6 Liter Hot Water Pot Logo
96 people viewed this question
Top Sunpentown Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Gregg Mahin
Gregg Mahin
Are you a Sunpentown Kitchen Appliances - Other Expert? Answer questions, earn points and help others
