Manual for Sansui Tv remote controle code sty - 0432 So that I can understand how to search for channels and how the buutons work and mean on the remote.
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
  • 54 Answers
SOURCE: Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
You will find all codes and needed information here...
http://www.hifi-remote.com/manuals/
Just look up your model number and wallah!
Posted on Aug 17, 2008
I need help to sete my remote for my SansuI T.V codes please thanks.
Posted on Dec 18, 2008
  • 87 Answers
SOURCE: reset codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Posted on Jun 14, 2009
  • 139 Answers
SOURCE: Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
Posted on Oct 17, 2009
Tv won't change channels
Could be on the wrong device. Click on the TV device and then try changing the channels on the remote.
Good luck,
Paul
Nov 11, 2016 | Televison & Video
Im trying to program the rca remote to my tv
Try any of the Sansui TV codes.
Sansui might be buying in some other brand of TV and rebadging it. Try the code auto search feature from the remote.
RCA code finder and support is here: http://www.rcaaudiovideo.com/remote-code-finder/ Download your user manual and have a read of the instructions.
Sep 09, 2014 | Televison & Video
How to unlock ASM in SANSUI SV-2010K
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
Aug 08, 2011 | RCA RCR311B Remote Control
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Can't find code for my sansui tv and rca universal remote
Code for Sansui TV are
1247
1191
Please try the above codes
Thanx
Jul 25, 2010 | RCA RCR311B Remote Control
I HAVE A URC-3220 ONE FOR ALL REMOTE AND AM UNABLE TO FIND CODE FOR SANSUI TV. ALSO I AM UNABLE TO FIND MY DIRECTIONS TO ENTER CODE. (MANUAL)
URC 3220 One for All Big Easy Remote Control
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sansui TV, and to download the urc-3220 manual.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Oct 20, 2009 | Sansui DTV2760 27" TV
Hi
Regards
Phillip
Aug 15, 2009 | RCA RCR311B Remote Control
URC 4220 will not operate 14" Insignia TV (NS-14FTV)
need code to set my urc4220 universal control for my zenith tv
Mar 22, 2009 | One For All URC4220 Remote Control
Ge universal remote
for the audiovox:
AUDIOVOX .................................. 0053
for sansui:
SANSUI ............................... 0135 0310
for the code search feature:
Code Search
If after trying “Direct Code
Entry” your device does not
code by following the steps
to the right.
be controlled.
VCR, etc.). The red
then stays on.
Jun 12, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
