Question about HTC Vivid
Powers off and on by its self now wont take charge it shows its charging but the red light is flashing and wont get off 0%
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
CHECK THE BATTERY AS WELL AS CHARGER...
Posted on Dec 26, 2013
3 Suggested Answers
ashlocked
  • 1140 Answers
SOURCE: My phone wont turn on and when I try to charge it,
First thing to do is try to replace battery for a test,usually when phone is often used,it can easily discharge like using wifi or any,then simultaneously charger is plug in.this will damage the battery and can be easily drained.
Posted on Aug 07, 2011
SOURCE: my htc wont change and just fashes a red light
Use brute force. I used ipad2 charger to kick start process then swapped to original charger after 2 minutes
Posted on Jan 16, 2013
Hp 110 mini will turn on and work but wont charge and the light is blinking steady red. Does that mean the battery is dead or the charging circuit is fried?
If you perform a normal charging cycle on your Netbook and it does not work afterwards, the battery may be unable to charge and will need to be replaced.
Jul 27, 2014 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
My htc wont change and just fashes a red light
your power supply is overloaded, check the power supply of your phone
Jun 08, 2012 | HTC One X Android Smartphone Glamour Gray
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Open Questions:
See all HTC Vivid Questions
HTC Vivid Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
