Question about Panasonic Microwave Ovens
I have a nn s950 ba microwave. It has stopped
I have a nn s950 ba microwave. It has stopped working, no power in the unit. Wall socket has power. What so I look for?
Kerry Alexander
Just a possible solution. Our microwave suddenly seemed deader than a door nail.
Our microwave was on a rolling cart. Without realizing it we had pushed the cart too close to the wall. The cart had pressed the on the wire connection with the plug and temporarily broken the power connection. As soon as pressure was removed from the connection, the microwave came back to life.
Posted on May 17, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Microwave stopped working. No power
please follow this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_4_57_51_pm.gif
Jan 24, 2013 | Panasonic NN-S541 Microwave Oven
Panasonic NN-651W microwave gone dead
There si a place called encompass parts that is a distributor for Panasonic, Look them up or call them with your model number and check price and availibility on the PCB
Oct 18, 2017 | Panasonic Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Jan 06, 2010 | Panasonic Microwave Ovens
Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
May 25, 2009 | Panasonic NN-S592 Microwave Oven
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Panasonic microwave no power or light
I must have suggested this 20 time today. if you open the casing you will find several fusees that the manufacturers don't want you to know about.
you have a 10 ampish large fuse that protects the power circuits ( transformer/magnatrons) smaller fuses for control circuits also might want to look atand reset the thermal cutouts. if it overheatedprior to failure
Feb 15, 2009 | Panasonic NN-C988W Microwave Oven
Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Jan 16, 2009 | Panasonic NN-H264 Microwave Oven
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
Microwave Ovens Logo
257 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
