Question about Husqvarna Viking 1
Bobbin on a Viking #1+ sewing machine
My bobbin thread comes out of the bottom plate too tight, demonstrated by the fact it breaks easily, pulls hard and stitches with the bottom thread flat and the needle thread looping around it.
I have cleaned out all the lint, loosened the bobbin screw until the thread really is too loose.
Maybe it is my bobbin. I just thought of that I will change it and see if that is the problem.
  • Husqvarna Master
  • 12,648 Answers
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Posted on Jun 19, 2017
watugot
  • 290 Answers
SOURCE: Viking Sewing Machine
Be sure you haven't missed a loop while threading the bobbin. If that's not it, check how well the bobbin is turning on the spindle. If it is threaded properly and you have cleaned it, I suspect you will find some damage to the bobbin that is causing it to bind on the spindle. If you have another bobbin, try it and see what happens.
Post back to let me know what you find.
Posted on Oct 19, 2007
bargainbox
  • 1388 Answers
SOURCE: thread loosens in bobbin case while sewing
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 26, 2008
mohammed387
  • 1952 Answers
SOURCE: sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Posted on Jul 20, 2009
SOURCE: viking sewing machine 545 bobbin stuck on rewind
Most machines you slide the bobbin winder to the right to wind and then back to the left when your done to remove. Just making sure.... you did move it back to the left?
Posted on Jul 28, 2009
bargainbox
  • 1388 Answers
SOURCE: Kenmore model 385.1764180 bobbin jam
Use a Ball Point needle for stretch fabrics....Janome Blue Tip # 11 are excellent....
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
.bargainbox.com.au
Posted on Aug 02, 2009
Trying to sew zigzag but the bobbin thread is showing up on top
1. Try to loosen the top tension first.
2. If this doesn't work remove the bobbin and tighten the bobbin.
3. The purpose of this is to have the top and bottom tension even. This is similar to a tug of war. Whichever way is stronger is where the knot will be going. You want the knot in the middle of the fabric.
4. Test your top tension by leaving the foot up. Pull the thread through back and forth. It should be easy. If it isn't you will need to adjust the tension mechanism.
There is a tension set document added to help you.
May 16, 2015 | Husqvarna Viking Emerald 116 Sewing...
Oct 17, 2007 | Husqvarna Viking 1
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
I want to adjust my bobbin tension on my 230 viking sewing machine but I don't know how.
1. remove the clear bobbin cover
2. slide the needle plate towards you and remove it, do not pry it upward or you'll break the gray plastic housing that supports it.
3. remove the gray plastic piece that is on top of the black bobbin case.
4. remove the black bobbin case from the machine.
5.Look on the side of the bobbin case for a small hole with a screw deep inside of it. That is your tension screw. Turning it to the right increases the threads resistance and left loosens it.
You know you bobbin tension is in the right range with the following test: Have your machine in the ready to sew positon. Meaning the bobbin has thread on it and it's in the machine and the bobbin thread is coming up through the needle plate. Gently pull on the bobbin thread to feel the amount of resistance. It should be slight not tight. If you pull on the thread and feel a light resistance your problem is not your bobbin. If you have looping on the bottom of your fabric, the problem is the top thread.
Dec 27, 2009 | Husqvarna Sewing Machines
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Feb 01, 2009 | Brother CS-8060 Computerized Sewing...
When threading my Viking sewing machine., the needle won't pick up the thread. I.ve used it 15 years. This is the 1st time this happened. Help...
Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
Apr 26, 2008 | Husqvarna Viking 1
Sewing Machines Logo
253 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
