Question about Skull Candy Smokin' Buds Headphones
Smokin budz 2 only sound clear when mic is pressed
My Skullcandy Smokin Buds 2 won't turn on even while it's charging. Just shows a steady blue light.
Same problem here. It is fully charged but I can't hear the little sound when you turn the headset on or off... It only worked the 1st month of use.....
May 09, 2016 | Radio Communications
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
China mic
I wish you provided more information to explain your mic problem. A mic may not be working because of any of the following:
1. cables (inside the mic housing or through out the cable length from the housing to the connector at the end) are not properly connected, either due to bad soldering or cable qualities.
2. problems on the mic switch: electronically (shorted internal components) or mecanically (loose "push to talk" rod or rod is too short so pressing the outter ptt bar does not activate anything).
Hope it helps. Goodluck, es
Jun 09, 2013 | Radio Communications
I just bought my smokin buds and it sounds like theres cracking or water in the right side of the earbuds
Do your old ones work ok?
If so take the new ones back and see if they can provide you with a pair that does not have the problem.
Jan 27, 2011 | Skull Candy Smokin' Buds Headphones
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Dec 31, 2009 | Philips Televison & Video
I need to replace plug on my skull candy smokin buds
the copper wires both go to the common/ground of the plug. those wires both connect to the contact that is closest to the cable. the other two connect to the other 2 contacts just pick either or.
Oct 08, 2009 | Skull Candy Smokin' Buds Headphones
When i plug in a mic, it wont work. under
You need to do the following
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
Aug 02, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
Aug 02, 2009 | Computers & Internet
I bought a Logitech webcam and the sound won't come though. It states my input level is not high emough but I can't find it to change it please
My understanding is that a webcam is only a webcam not a webcam+mic (mic=microphone for sound to be input) unless your webcam has video and sound capabilities.
1. get a mic
2. if you webcam is supposed to be also a mic, (I have yet to see one of those myself) you should hook up the connector for the microphone (usually a a red trs plug/connector) to your pc.
3. make sure your have run the video/sound wizard of your instant message application to test your video, mic and speakers. (to see, talk and be heard and hear what the others are saying)
are you trying to hear what the other person is saying when having a video conversation?
1. check your speakers are properly connected, powered and turned on.
2. check your speakers (and mic aswell) are not muted (check your speaker icon on the system tray and check your volume controls by doing right and/or left click on the speaker icon on the system tray.
4. make sure your sound adapter's drivers are installed and your device is working properly (check device manager by going to start>run> type devmgmt.msc the press enter and make sure that under sounds you don't have any ? (no drivers) or ! driver problem for your sound adapter.
Sep 27, 2008 | Gateway Computers & Internet
Sound problem when video camera is turned on
1.Check whether your cam has built in mic.
2.if then connect the mic signal cable to the MIC in connector in your sound card.
3.if your webcam doesnt support MIC functions. Connect the head phone with mic to mic/audio slot
4.if you have already connected Mic. then the problem with the sound card settings in the instant messenger menu.
5. Specify proper sound card manufacturer in the audi settings found in the preferences or options or settings menu in IM software.
thank you !
Dec 20, 2007 | Computers & Internet
Skull Candy Smokin' Buds Headphones Logo
52 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
