Question about Lionel Crafts & Hobbies
Thomas train 7409
Wheels will not turn
SOURCE: Peg Perego Thomas Train Track Rider
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Posted on Dec 21, 2008
  • 80 Answers
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Posted on Mar 24, 2009
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Posted on Jun 01, 2009
  • 156 Answers
SOURCE: Thomas Train
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Posted on Jul 22, 2009
SOURCE: Have lost instruction manual for THOMAS ULTIMATE TRAIN SET byTOMY
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Posted on Nov 24, 2009
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
Where does Stanley the train's battery go
There are apparently 2 different models of the Stanley train for the Trackmaster. One comes with a tar car and one is by itself. If you have the one with the tar car, the battery goes in that. If you have the one that comes solo, then you have to flip it over and in the middle of the bottom is a small screw that you have to unscrew and remove the middle wheels to take the top off. Once you have the top off, the battery is located there. I hope this helps.
Jan 22, 2011 | Seth Thomas Thomas & Friends Percy Train...
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Nov 11, 2010 | Thomas and Friends Trackmaster Motorized...
Does anyone have information where you can get replacement rubber tires / wheel grips for Brio electric train engines? (wooden tracks) We have a few electric engines that can no longer climb the hills...
I dont know where you can get replacement tyres. But here is a fix for the problem:
Using tweezers then fingers, pull off the existing tyres.
Take ordinary sewing thread, and wrap it around the V in the wheels (where the tyre was), about 20 turns or so, keeping the ends inside the V.
Put the tyres back on.
The thread forces the tyres further out, making some tread from the rubber available above the level of the plastic wheel rims.
Nov 06, 2010 | Thomas and Friends Repair Garage Fits...
Battery instolation
mcdevito75 here, I believe the battery--ies go in 1 of the wheels, try looking for a cover or squeeze 1 of the wheels for cover to pop off.
Jul 02, 2010 | Thomas The Tank Engine Ben
The motorised chassis of our second-hand Tomy THOMAS THE TANK ENGINE Big Loader Train set is not working properly. The motor grinds away but the wheels don't turn. Does anyone have any pictures of the...
Hi I dont have a solution but found you can buy a new chassis from tomy uk for about 5 pounds. I also found a guy on eBay called thatwasfun who repairs tomy Thomas things for $10
Apr 21, 2010 | Tomy Thomas The Tank and Friends Track
Dec 16, 2008 | Peg Perego Vespa Scooter
Crafts & Hobbies Logo
26 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
