Question about Nikon D7000 Digital Camera
Flash on camera is not working
Flash pops up but will not flash
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 11 Answers
Hello. If you're shooting in Auto mode and you have turned off the flash, your camera will remember that setting and the flash will not fire. If you switch the dial on top of your camera to another mode and then back to auto it should clear the setting and the flash should now fire, if needed. The other thing to try is to hold down the the flash popup/mode button while, at the same time, turning the rear control dial. You can watch your top display and the flash modes should cycle through different options.
Posted on Jan 05, 2014
Canon flash won't pop up
Flash will not pop up automatically if you're in manual mode. Try putting it in the green auto mode, then try again. Still not working? See if the little flash symbol button is on OFF. If so, put it to ON or auto. Should work.
Jul 08, 2014 | Canon EOS 40D Digital SLR Camera Digital...
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
DSC H-5 the flash pops up but does not flash, camera is set to automatic mode and flash is turned on.
Flash pops up shows that flash release mechanism is working as camera wants to flash.
There are 3 thick wires connecting between flash bulb and flash charging circuit in camera, one of thick wire seems internally broken and causing problem.
Camera will be apart to check wires.
Let me know, if you are willing to apart camera, for further help.
Thanks.
Dec 31, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Nikon D80 flash won't pop up
Must be a problem with the flash lock. Try to pop up the flash manually using the flash button located at the top left of the camera beside the flash. If this does not work, you may need to have the cam serviced
Jun 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Olympus evolt 500 - Flash won't pop up
did you have the auto pop up in the menu on?
Jun 20, 2009 | Olympus EVOLT E-500 Digital Camera
Flash doesn't work
Check your flash setting (the button with a jagged lightning bolt) to make sure that you have the camera set for auto flash. Push the flash setting button until you see a bold A next to the lightning bolt. Sometimes the user inadvertently covers or even just touches the flash unit while powering on the camera, preventing the unit from popping up. Many Kodak cameras have a manual button (marked with the lightning bolt and the word OPEN) to pop the unit up so that it will work for you. Hope this helps.
Bill B.
San Antonio
May 05, 2009 | Kodak EasyShare Z1012 IS Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D7000 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
