Question about ASUS EA-N66 Dual-Band Wireless-N900 Gigabit Ethernet Adapter
How to reset a ea-n66r
How do i reset and start the setup process over
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Posted on Mar 09, 2013
Tip
Ea electronic art freedom fighters pc
<pre>
tips.....
too fast and crash audio unsync
this because your pc is too fast
this works on winxp, not tested on ther os but try the same proccess might work..
2 option is available
1. on freedom fighters directory look for freedom fighter.ini open it and
find disablevsync (change this to enablevsyc) then right-click on
application ico then select properties change the
compability to 95 or 98 ( this sync does not include audio
2. start the game then alt+tab then endtask ctrl+alt+del then find
freedom fighters.exe right-click change affinity and disable either
1 or 0 cpu to reduce cpu processes speed, and back to game now
you can observe the audio is sync w/o eax creative audio card
by korotchan
note: everytime you start the application need to repeat 2nd step.... taskman resets the setting, or you can use processes control application
like coreaffinity application
</pre>
on Nov 01, 2010 | Video Game Consoles & Games
Sony vaio vpcea3bfx /l very slow i5 ram 8gb w8.1
possibly a virus try resetting to factory default or it could be that you have to many backround programs / processes ruunning
Mar 18, 2014 | Sony VAIO EA Series Brown Notebook...
My laptop will not start
If this is the first time that you turn on your laptop after resetting it to the factory settings then don't do anything while setup is starting services because you will just mess up the computer. It's really gonna take time to start the services. It's still in the set up process - it's loading some files on it.
I hope this helps!
David
Feb 22, 2013 | Acer Aspire 5750Z-4879 : 2.2GHz Pentium...
Asus RT-N66R router for wired operation
  1. Plug in your ISP modem to the uplink port on ASUS router.
  2. Plug in your computer to any other port.
30 sec setup - http://youtu.be/fNcPg2lfjVw
Sorry Tom?
Oct 10, 2012 | Computers & Internet
The gui setup wizard is not popping up/opening and i cannot access www.asusrouter.com
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see 10.0.1.1? That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
How to unistall EA SPORTS(TM) Cricket 07 from my computer
Go "Start" > "Configuration screen" > "Remove a program".
Look for the game in the list, click it, and press "uninstall".
Otherwise, you can also just go "Start" > "All programs" > "EA Games/Sports" > "Cricket 07" > "Uninstall".
Both gets you trough the intalling process easily.
May 25, 2010 | EA Sports Cricket 07 for Windows
Lost manual so can't enter code found at back of manual for lord of the rings The Battle for Middle-earth
If you registered your game when you did the original install, EA Support should be able to help you out, although they are notoriously slow to help their paying customers. This I know from personal experience, but, in all fairness, if you keep at them they will, as a rule, remedy the situation.
Just a sidenote: When you submit your support ticket, and start receiving emails from EA, save them and address your replies to the representitive who starts the process...It seemed to expedite the process for me when I had issues with NFS Carbon, NOT having to explain the issue to three or four different reps.
Oct 04, 2009 | Microsoft Windows XP Professional for PC
When i m playing ea sports cricket 2007 then there is written missing texture on every thing like bat on player ............so please help me when i am starting the ea sports cricket2007 game ,it is...
even i had a problem like that. i]this problem comes when your system needs more requirement to play this game or if the game is not installed correctly.
i installed another setu and got the game.
try intalling from some other setup file. or else update your ram and videocards
Jun 01, 2009 | EA Sports Cricket 07 for Windows
ASUS EA-N66 Dual-Band Wireless-N900 Gigabit Ethernet Adapter Logo
146 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
