Question about Honda EU6500iS Inverter Generator
Rough running surging - Honda EU6500iS Inverter Generator
I am experiencing a problem with engine running rough surging and cutting out. Tried all the obvious no result
engine running rough surging and cutting out Dj. A lot of things could cause this issue. First thing to do is have vehicle scanned for trouble codes, a good Tech. then can diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The dreaded engine surge Automotive Service Professional
How to solve engine hesitation and stumble problems on the90
Diagnose Engine Stalling Problem
Jul 28, 2016 | Cars & Trucks
2000 ford explorer run but no power
Mark, I think it needs a tune up. when were the spar plugs replaced or checked. Any kind of build-up can cause sluggish and rough perfomance.
Feb 06, 2014 | Cars & Trucks
Runs rough after warm-up
jshuffman: Believe it or not your ignition module (located behind the coil packs) could be the problem. If your cooloing fans are not working either, this is the culprit. The worst part is that it won't always show a code on the old obd 1 systems. This module controls more than you think along with the computer on this type of car. Good luck. Hope this helps. P.S. Air conditioning will quit working too.
Feb 10, 2013 | 1990 Oldsmobile Cutlass Supreme Conv
I put in anew oxygen sensor but the engine still runs rough and surges in park
try checking yoru vacumm pipes maybe one has a little split this will cause it to run a little rough
Jan 06, 2011 | 1995 Toyota Tercel
Has low power, surges @ cruizing speed, rough idle (code 32)
You can remove the egr and see if it has been sealing,and if it still moves.
Jan 29, 2010 | 1993 GMC Sonoma Club
Engine run rough at idler and surges
I would change the fuel filter and see if that don't help. You might give it a good tune up and adjust the timing. ( If it has a carburetor then adjust the carb too.
Apr 08, 2009 | Nissan Pickup Cars & Trucks
I have a 1988 Chevy C3500 1 ton PU. Engine runs great at idle and acceleration but when cruising it runs rough or surges.
if the truck has a locking converter goin bad it will surge at steady speeds such as 55 mph the converter will lock and unlock causing you to feel an surging
Mar 07, 2009 | 1988 Chevrolet C3500
Honda EU6500iS Inverter Generator Logo
61 people viewed this question
Top Honda Electronics - Others Experts
Bill Boyd
Richard Warren
Richard Warren
Geoff White
Geoff White
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
