Question about Maytag Washing Machines
Washer will not agitate, during this step, clothes just sit in water filled tub. once timer moves past this function, it continues to spin and drain like normal. I just put in a new timer, thought that was the issue. did some reading that it may be a clutch or coupler. I have no clue??? Bill Maytag model MAVT754EWW
  • azcamp305 May 17, 2009
    thanks for the quick reply!! I found a clutch assembly, Part number 2670, for $34.85 online. How do I inspect it, is there an access panel, or do I have to tip the machine to look underneath?
  • azcamp305 May 18, 2009
    thanks, now I just need to figure if its worth the effort or go for new.
  • 6,784 Answers
Hi, anytime the washer doesn't agitate at the time that is ordered to , this will confirm that the clutch assembly has failed. the clutch is part of the drive assembly and it works within the gear box(transmission. you will have to replace this device. there is also a shift aculator that works with the transmission as well. this could be an issue also.
I recommend inspecting the drive Assembly and clutch for broken or stripped components.
Posted on May 17, 2009
  • Michael Masters
    Michael Masters May 17, 2009
    Actually, you will have to disassemble.y the entire drive assembly to get a good clean look at what the issue may be. you will have to remove the drum form the drive and gear box.
  • Michael Masters
    Michael Masters May 18, 2009
    The hardest thing about this repair is the disassembling part of it but, the actual clutch replacement is a moderate issue at most.
    It will take some time and a assistant would be a good idea to have around if possible.
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Maytag washer will not cycle.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
