Question about Kodak Easyshare C195 14 Mega Pixels Digital Video Camera
Lines on screen
LCD screen
    New Friend:
LG flat screen 50 inch
Posted on Apr 22, 2014
Does a vertical line appearing on a screen of a lcd hd tv mean the lcd screen is bad?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
1/4 of my sharp aqous tv has lines in it
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Aug 26, 2011 | Sharp LC-52D62U 52 in. LCD HDTV
I have a 47" Vizio
This problems the tv serveral vertical lines show up on the LCD screen panel by itself?Yes,the tv board that call the T-CON decodering board is dying.The T-CON decodering board it sit at the middle bottom of the LCD screen panel.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.If these vertical lines cause by an object or a person by hitting the LCD screen panel,tv is not repairable,because the LCD screen panel is dead not worth replacing because the LCD screen panel are 90% important to the tv and cost the same as a new tv.
Mar 26, 2011 | Vizio VO47L 47 in. LCD TV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Lines on my display screen too.
More than likely you will need to replace the LCD screen. When it got wet, it probably damaged the LCD screen. Usually it justs blows them completely out.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is extremely easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the 580i LCD display and links to buy the screen.
Sony Ericsson W580i LCD Screen Replacement
I hope that helps you out
Jul 10, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Lines on phone
More than likely you will need to replace the display screen. Those lines are a symptom of the LCD screen going bad. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
Jun 03, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Screen showing funny lines and colors.
That would be the screen itself that needs replaced, if you needed the inverter board you screen would be dark and hardly visable
Nov 12, 2008 | Acer Aspire 3100-1405 Notebook
Screen has lines
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
Jun 27, 2008 | Kodak Easyshare M753 Digital Camera
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Kodak Easyshare C195 14 Mega Pixels Digital Video Camera Logo
116 people viewed this question
Top Kodak Video Cameras Experts
richie46
 steve
steve
Are you a Kodak Video Camera Expert? Answer questions, earn points and help others
