Question about Toys
Hak 301 won't charge - Toys
Hak 735 helicopter
Usually synching requires one device started before the other, meaning that you may want to power on the transmitter, then turn on the heli and try the heli first, then the transmitter second if that doesn't work. Otherwise there's usually a small button that is pressed to get the two devices talking to each other.
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
Feb 09, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
I found a motorola L6 and i don't know the code how to hak in it
if you don't know the code.
Go to your nearest compurterized mobile phone servise station
Sep 22, 2011 | Computers & Internet
I want short cut for yahoo mail
to visit yahoo mail http://ymail.com
and if you want to browse and read your email without opening your internet browser you can use:
Thunderbird from http://www.mozillamessaging.com/thunderbird/
May 23, 2011 | Yahoo Mail
How do I hak into my own laptop
just log in u have the control of ur sys :-)
Feb 06, 2010 | Computers & Internet
Forrunner 301 won't turn on or charge
You can try various resets to see if you can get it to respond.
Have you tried plugging the unit into the wall instead of the USB
port.Do you get the Battery Charging message at any time.You can
try a soft reset.Press mode and reset.Then try to power on while
plugged in.A hard reset will delete all your data and settings from
the Forerunner.Press the Power and the Mode button until the unit
comes on and asks if you want to erase all user data.Select Yes.
If the above won't work, try a hard reset that by-passes the
confirmation screen.Press Mode, Reset and Power.
Oct 29, 2009 | Garmin Forerunner 301
My crockpot's cable was damaged from heat.
amy i would try to tell you how to fix this but i would cost you some money to buy all the things to fix it you might try to go to a tv repair shop and see if they could put another cord on it for you they might charge you 5-10 dollars for this k
Nov 03, 2007 | Rival 37601 6-Quart
Toys Logo
145 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
