Question about Wine & Spirits
My black grape vine had developed black spots on some of the grapes
5 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Posted on Jul 22, 2008
SOURCE: Colorado over heating
then you will need to have it diagnosed or have the thermostat replaced. Since it only does this on a hill most likley doagnosing it will be a waste of time since noone has a hill like the grapevine to test it.
So get the thermostat and a coolant flush done. Thats about all you can do other than replacing the sensor or the gauge
Posted on Dec 19, 2009
Testimonial: "First suggestion that makes sense to me. Coolant is not a problem as the truck has less than 8,000 miles and is not 2 years old. "
duane_wong
  • 6826 Answers
SOURCE: We just purchased a 2005
Well, it's a good idea to change the timing belts every 80,000 mi. or so, and sooner under severe service. However, I have not heard about Buicks from the 2005 model year having a particular problem with the timing belts, more than any other brand.
I read over the gasoline engine recalls and didn't see it listed.
Posted on Feb 12, 2011
  • 9845 Answers
SOURCE: Can I cut back the side arms on a 2nd year grape vine since they are growing too long past my support post during the growing season?
Yes you can Spring time is the best time since there is more sap in the vines.
Posted on Jun 07, 2014
Testimonial: "Thanks for the advice, much appreciated!"
I HAVE CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP
Have a read. Disease, pests or virus.
Grape Diseases and Drying on the Vine ' Home Guides ' SF Gate
homeguides.sfgate.com > Garden > Pest Control
  1. Cached
  2. Similar
The leaves become mottled with tiny black spots and the fruit also bears dark spots. ... Most of the diseases that cause drying grapes on the vine are fungal ...
Why Are the Grapes Dying on the Vine? ' Home Guides ' SF Gate
  1. Cached
  2. Similar
Luckily, the fungi, insects and bacteria that cause fruit to rot or wither are easily ... Summer bunch rot-infected grapes have black, brown or green powdery fungal ... Removing leaves at the base of stems once grapes have set helps control both ... Best Time to Pick Concord Grapes for the Best Flavor ยท Grapevines & Leaf Curl ...
What Are the Causes of Grapes Turning Black Before They Ripen ...
  1. Cached
  2. Similar
If your grapes turn black on the vine before they ripen, the cause is usually black rot. ... which helps prevent infection by speeding the drying of leaves and fruit.
Why are my grapes turning dark and drying up before they ripen ...
https://ask.extension.org/questions/199835
  1. Cached
  2. Similar
Jul 16, 2014 - Minimize black rot problems by removing infected fruit, cleaning up mummies, and pruning out leaves that surround fruit clusters. See fruit links ...
Grape Diseases ' Integrated Pest Management Program - MSU IPM
www.ipm.msu.edu/grape_diseases
  1. Cached
Oct 16, 2014 - Leaves develop numerous dark brown spots, 1/25 to 1/5 inch (1 to 5 mm) in diameter. ... resulting in distinctive clusters of dead vines within the vineyard. ... Berries that do not fall off shrivel up, similar to black rot-infected berries. .... This disease occurs only in Concord and Catawba grapes in Michigan.
CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP Google...
Aug 14, 2017 | Cooking
I want to plant grapes...how and when do i do it
https://www.arborday.org/trees/fruit/care-grape.cfm
How to Grow Grape Vines
How to Grow Grapes in Your Backyard
How to grow grapes RHS Gardening
Consider consulting your county extension agent who may have access to publications about such as well as special knowledge about your area.
Jan 25, 2017 | Wine & Spirits
We planted new grape plants a few months ago. Now have little grapes forming along the vines . Just need to know can I cut off the long vine/cane just after the last bunch.
Unfortnately, those grapes need to be pruned off the plant for two years to make the roots and the plant stronger.
  • In the first couple of years, the vine should not be allowed to produce fruit. It needs to strengthen its root system before it can support the extra weight of fruit.
  • Pruning is important. Not only would vines run rampant without control, but canes will only produce fruit once. Prune annually when vines are dormant, in March or April. This is before the buds start to swell, but when winter damage is apparent.
  • Don't be afraid to remove at least 90 percent of the previous season's growth. This will ensure a higher quality product.
  • Remember, the more you prune, the more grapes you will have.
  • In the first year, cut back all buds except for 2 or 3. Then, select a couple of strong canes and cut back the rest. Make sure the remaining canes are fastened to the support.
  • In the second year, prune back all canes. Leave a couple of buds on each of the arms. Remove flower clusters as they form.
  • Do not fertilize in the first year unless you have problem soil. Fertilize lightly in the second year of growth.
    Read this article in full
    Grapes
  • Nov 15, 2016 | Wine & Spirits
    I have seen AOC written on several wine labels. What does this mean?
    AOC can be found on bottles of French wines, it stands for Appellation d'Origine Controlee. It refers to specified regions, with controls on several aspects including: variety of grape, density and size of vines, maximum yield, minimum alcohol level and processing techniques.
    Feb 03, 2013 | Wine & Spirits
    What is Ice wine?
    Ice wines are manufactured in cold climates, most often Germany or parts of Canada. To make an ice wine, grapes are left on the vine until they start to become raisins and then freeze. Timing of harvest (in relation to climate) is very crucial in the process of making ice wines. Temperatures of -7C or below are needed to produce a good quality ice wine. The combination of the overripe grapes with the concentration leftover from removing excess water from frozen grapes results in a sweet tasting wine.
    How are wines named?
    Wines are named for one of two reasons: the grape variety or the region where the grapes were grown.
    The first type is named after either the sole (or principle, if blended) grape variety that makes up the wine. Many times a wine is blended; you may not find that information on the label. Each country has its own specifications that dictate the minimum percentage of the named grape that a wine must contain.
    The second way to classify wines, by their region, is quite common in Europe. Instead of the label dictating whether the wine is a Merlot, Syrah, or Cabernet Sauvignon; in this case, the label will say Burgundy, Bordeaux, or Sancerre. This technique is used because many of these regions are famous for a certain grape variety.
    What is dessert wine?
    Sweet or you can say dessert wine is produced with extra sweet wine grapes. In order to make them sweet, the fermentation is stopped before the yeast turns all the natural grape sugar into alcohol.
    For more Details you can Visit :
    5 Types of Dessert Wine Wine Folly
    You can order wine for any occasion like birthday, anniversary or any other event like corporate event and many more.
    http://www.giftblooms.com/USA/Wine-Delivery
    Can Concord grapes be juiced with the Jack LaLanne juicer? Are the seeds to large and hard?
    you can juice grapes but you will hav to put in another fruit thats hard like a carrot apple celery to push the juicer from grapes out
    Aug 18, 2010 | Microwave Ovens
    Wine & Spirits Logo
    224 people viewed this question
    Top Wine & Spirits Experts
    Don Hart
    Dave braun
    Dave braun
    guymark
    Level 1 Expert
    Are you a Wine and Spirit Expert? Answer questions, earn points and help others
