Question about Apple iPhone Cell Phones
Error code E000025 cant import from iphone to laptop
Cant import pictures from iphone 4 to my laptop with windows 7. Gives me an error code E000025
  • 59 Answers
SOURCE: E000025-0001
It's to do with the Magenta toner supply motor sensor. Toner drops out of the cartridge andin to the sensor which is situated elow it. The best way to fix it is to remove the grey cover below the toners and blow out / vacuum out the area. There is a modification availiable. I'd speak to your service company though.
Posted on Apr 02, 2009
hquiteculo
  • 19 Answers
SOURCE: Error code E000025-00001
there is a toner feed motor over currente detection error, there is a toner botle motor connection detection error.
1- check the connector for any fault in connection.
2- replace the motor
Posted on Apr 09, 2009
  • 13 Answers
SOURCE: What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Regards Mug71.
Posted on Sep 14, 2009
thinktech09
  • 177 Answers
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Posted on Jun 11, 2010
Tip
How to import photos from iPhone to computer
No matter you own a relatively old iPhone 5 or a span-new iPhone 6, you may have hundreds of photos stored on your iPhone with its limited storage. If your iPhone is 8 GB or 16 GB, there is the great possibility that one day your iPhone storage is running out space for the photos.
To free up space on your iPhone, here you can get two ways to import photos from iPhone to computer.
Part 1. How to import photos from iPhone to computer with Windows AutoPlay
1. Connect your iPhone to the computer. If the AutoPlay window appears, click "Import Pictures and Videos using Windows".
2. Click the Import Settings link > In the resulting window, you can change the folder to which your Camera Roll's photos will be imported by clicking the Browse button next to the "Import to" field.
3. After setting your import options, click OK > Choose a tag if desired and click Import.
Part 2. How to Import Photos from iPhone to Computer with AnyTrans
1. Download and install AnyTrans on your computer, then connect your iPhone to the PC.
2. Open up AnyTrans, on the homepage, click Photos button.
3. Choose the photos from Camera Roll/Photo Stream/Photo Share/Photo Library/Album/Panorama/Bursts(Which is various depends on your iPhone mode).
4. Click the To Computer button to import photos from iPhone to computer. Resource from: How to Import Photos from iPhone to PC on Windows 8 7
on Apr 15, 2015 | Apple iPhone Cell Phones
Can I download my pictures from my phone to my computer?
If your phone manufacturer hasn't got a program, For instance Samsung has a prog named KIES, then I suggest your send each picture as an email attachment , its slow but it works.
Oct 10, 2014 | Apple MD439LL/A iPhone 4 Verizon 8GB...
How do I upload photos from my computer to my iphone 5c smartphone?
How to Transfer Photos: Windows Vista/7 Users If you have Windows 7 or Vista, there are two easy ways to transfer your photos directly to your desired folder or directory.
AutoPlay Method
When your iPhone device is connected, click on the Start Menu, and then Control Panel. Click Hardware and Sound. Select AutoPlay, scroll down to find where your iPhone device is listed, open the drop-down menu, and select "Ask me every time."
Step 1 - Connect your iPhone device
If you enabled the AutoPlay behavior using the method described above, you can skip this step, because your iPhone is already plugged in. If not, connect your device using the appropriate USB cable that your phone came with.
Step 2 - Import Pictures and Video
The AutoPlay prompt should appear with your device type listed at the top. Click the first link that says "Import Pictures and Video."
If for some reason the AutoPlay prompt did not appear, go to Start, then Computer, then right click on the icon for your iPhone device and select "Import pictures and video" from the context menu that appears.
Step 3 - Choose a directory, and import
Before you click Import, go to Import Settings, and select the "Import to" field to select the destination you want your photos to transfer to. By default, they will transfer to your My Pictures folder. You can also select the "Always erase from device after copying" option, though this is, as always, optional.
Click OK, then click Import, and your photos will be transferred to their designated directory.
Windows Explorer
If you don't want to mess with AutoPlay, you can find and transfer your photos manually using Windows Explorer.
Step 2 - Click Start, then Computer
This should take you to a Windows Explorer page that lists your hard disk drive(s), and devices with removable storage. If connected properly, your iPhone device will register as a device with removable storage, and you will see the icon for it listed below this header.
Step 3 - Double-click your device's logo in Windows Explorer
Double-clicking your device will open it up as a directory, full of folders and sub-folders that store all of your phone's content.
Step 4 - Open your camera folder
Your camera folder should be located in [Your iPhone Device]\Internal Storage\DCIM\100APPLE. This means once you're in your iPhone's directory, click on the Internal Storage folder, then the DCIM folder, then the 100APPLE folder.
Step 5 - Transfer your photos
You can import your device's photos by selecting the ones you want, or pressing Ctrl+A to select them all, and dragging them onto your desktop. Or, you can hit Ctrl+C to copy the photos, and then hit Ctrl+V in the folder you want to copy them into.
Oct 03, 2014 | Apple iPhone 5c 16 GB Green Smartphone -...
Windows 7 error code 0x80040154 in backup and restore
What is H Drive? You want to change it to what? C drive? Can you clarify. Perhaps this will help: http://support.microsoft.com/kb/979281
Apr 15, 2013 | Computers & Internet
Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
Jan 10, 2010 | Asrock K7VM3 Motherboard
Importing Error
The problem is probably the same one i had. After successfully importing videos and pictures from my SD card, Windows 7 started giving me that error. I discovered that it was caused by the fact that I had imported some directly to an external USB hard drive (E:) and had set the default import directory to it (I can't remember if I had done this dileberately, or if W7 remembered it).
Fix: Just before you start the import, click the more options link at the bottom, and change your default folder to the local drive or to an attached external drive, something that exists at the time.
Worked like a charm after that!
Bill
Singer/Songwriter
www.billandkateisles.com
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
E000025-0001
Apr 02, 2009 | Canon Office Equipment & Supplies
Mar 19, 2009 | Canon imageRUNNER 5570 Copier
Cell Phones Logo
504 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
