Question about Refrigerators
Light not working. Replaced bulb and it still does not work. Suspect switch is bad. How do you remove switch? Kenmore model 363.9631513 It seems like it might snap out. I don't want to force it though. It's a top freezer type refirgerator from 1993.
  • 10,865 Answers
First make sure that the "new" bulb is indeed working, by screwing it into any lamp socket. If the bulb is good then you are correct in thinking that the switch is the culprit. Yes, it does snap in and snap out. Put a blow dryer on it for a few minutes to make it a bit more plyable then put a putty kniife blade under each side to loosen it up.
Posted on May 17, 2009
  • Joe Hogan May 17, 2009
On a Kenmore side by side refrigerator that has two light bulb sections, what causes the lights not to work?
The door switch provides a source of power to two things. Yes the door switch can be bad. What is your model number? There was some models that left the lights on when the door was closed and people would unscrew the bulbs just to sell them to people unaware. That problem was related to a bad relay on the motherboard
APPLIANCE 911
Nov 28, 2015 | Kenmore Refrigerators
My kenmore light won't come on after changing bulbs
Hello. This model is a MICROWAVE. Are you sure the bulb you replaced was defective? And are you sure the replacement bulb is good? It's very easy to break the filament inside and due to the gorillas who ship this stuff, you wouldn't be the first to put a new, bad bulb in! One of the door switches is part number 503387 and there are 2 of them in the switch holder. The third switch is part number 3B73361E. The whole switch holder assembly with switches is part number 3501W1A019C. The part number for the main board is 6871W1S128A because *there might be a faulty relay on the main board causing the light to fail*.
Sep 02, 2015 | Kenmore Kitchen Ranges
The light won't work, I changed the bulb and it still will not work
Probably bad door switch. Look for a roughly triangle shaped piece of plastic that goes into its housing as the door closes. This is the door switch. Probably a similar one at the freezer door too. Snap this switch a few times with a good bulb in place. If bulb lights even once it is the switch. BE SURE BULB IS GOOD by trying it in a room lamp first.
Door switch can be pried out using a dull knife around the plastic. Do this with the power cord unplugged. Switches like this are common to many Kenmore or Whirlpool models.
Sep 09, 2009 | Kenmore Refrigerators
Dimmer light won't work.
you are using incandescent bulbs because most dimmer will not work with Fluorescent otherwise sound like a bad switch, if it new return it. They are fairly easy to replace. Hope this Helps Paul
Jun 17, 2009 | Kenmore 51840 Kitchen Hood
Washer wont progress through the cycles, suspect timer.
I was able to fix the problem by replacing the timer ($106 CDN). Thanks for everything.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
