Question about Sega Virtua Tennis for Windows
No supported audio device found - Sega Virtua Tennis for Windows
Lg x130 no audio device found
Here are the drivers. Choose OS and look for Realtek. Best of luck installing.
http://www.lg.com/ae/support-product/lg-X130-L.A7W1E
Sep 27, 2012 | LG X130 Netbook
Microphone cannot detect for Fujitsu LH530, audio device cannot found...
Try to check Audio device under "Device Manager". To do so, you can click Start > type devmgmt.msc on the startsearch box. The audio driver might be corrupted causing the problems that you are encountering. Download the Audio driver from the Fujitsu support website.
I hope this helps.
May 06, 2011 | Computers & Internet
My audio device no found
go to control panel/system security/device manager device mager/ scan device if you see a driver yellow icon like this(?) click it audio device and update driver online. step by step. automatic run online...
thank you...
Feb 01, 2011 | Acer Aspire 5050 Notebook
When i am installingconxtant audio driver it is telling media device not found and not installing
Typically, if you are getting a "device not found" error upon trying to install an audio device driver, there are a number of issues that could be going on at one time.
First: You may have the wrong device driver or version of the device driver for the device intended for. Check the hardware version number and verify on the website of the hardware device (the audio card if it is an independent audio card that is what you are referring to) what is the latest revision of the driver. Download the driver and install it.
Second: If your device is an external audio card, make sure it's fully inserted into the PCMIA slot (seriel port if being used). If so, then accomplish the following procedure: Power down your PC. Remove the Audio Card and reboot PC. Allow PC to recognize no audio card, then shut down PC and reinstall Audio Card. Reboot PC and install with new Audio Driver
One of the two steps above should rectify the problem. If it doesn't, then the last resort is to assume the Audio card is faulty if it's an external Audio card.
If you have an internal Audio card, then there can be a faulty portion on the sound portion of the motherbood, which then would require the entire motherboard to be replaced. But before you result to this, be sure you have the newest Audio driver for the Audio Codec and installed correctly.
Please keep in mind, Conexant is an OEM supported Audio Codec and you need to refer to the maker of the PC itself for driver support. I.E. it may be a Conexant Audio chipset installed in a HP PC. So, be sure you go the manufacturer website such as "HP" for the audio driver support.
Hope this helps,
Jun 26, 2010 | Computers & Internet
No audio device found on computer
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my support page.
all the best...
Dec 31, 2009 | E-Machines eMachines Desktop PC
No HD Audio Device Found
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a folder on C:\drivers Then install the various drivers from this folder.
Dec 08, 2009 | IBM ThinkPad T43 Notebook
Dell inspiron 1501 no audio device found
Before install audio driver from here http://support.dell.com/support/downloads, you must install Universal Audio Architecture, UAA driver first. http://support.microsoft.com/kb/835221
Aug 11, 2009 | Dell Computers & Internet
No Sound
the sound driver can be found here
http://www.trigem.com/driver/AMERICA/6.14.01.3890.zip
the rest of the drivers for your laptop can be found on there site also at http://www.trigem.com/us/support/drivers.asp
Nov 29, 2008 | Averatec 3200 Notebook
Sega Virtua Tennis for Windows Logo
82 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
