Question about ETL Secure Logic 20710 Keypad Wall Vault
Password change for secure logic 20710
How to reset the password for secure logic 20710?
I'm trying to auto fill my phone card. The phone belonged to my sister and had her info in it. how do I change to my info.
Janet, You may have to do a factory/Hard reset, the links below will show how. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG L3 Optimus E400 Hard Reset Remove Password
TracFone LG Optimus Logic LGL35G Master Hard Reset Recovery Mode Menu...
LG Optimus Logic Videos
May 04, 2016 | Straight Talk LG Optimus Logic Cell Phone
Tip
Tricks for Keeping SQL Server Safely
Some simple ways to protect your SQL Server database
1. Using the Microsoft Baseline Security Analyzer (MBSA) to assess the server's security
MBSA is one of a variety of Microsoft products, which can scan unsafe configuration tools. It can be run locally; you can also run through the network.
2. Isolate your server and regularly back up
Physical and logical isolation would form the basis of SQL Server security. Database should be installed within the enterprise network security area, but not directly connected to the Internet. Back up all data regularly and store copies in a safe location outside the site.
3. Assign a strong SA password for a SA account
SA account should always have a strong password, even if Windows is configured to require authentication of the server. This will ensure that the server has been reconfigured in the future as Mixed Mode authentication; it will not appear blank or weak SA.
4. Restrict the permissions SQL Server service
SQL Server 2000 and SQL Server Agent is running as a Windows service. Each service must be associated with a Windows account, and derive from this account security context. SA log in SQL Server allows the user (sometimes including other users) to access the operating system features.
About reset SA password in SQL 2008/2005/2000
To secure our database we would like to choose create an intricate password. But even our selves would forget the SA password in SQL Server 2005/2008 sometimes. So here is a way for you to reset SQL Server 2005 password -- MS SQL Server Password Unlocker, which is a highly A Highly Technical and Safe SQL password 2005 Recovery tool. And following is a few features of the tool.
Features:
* Support SQL Server password recovery for MS SQL Server and MS SQL Server Express 2008/2005/2000
* No need to install MS SQL Server on your PC or lose data, the file master.mdf format is necessary
* Stop and resume MS SQL service automatically if the MS SQL Server on your PC is running
* Reset SQL password with ease no matter how long and complicated the SQL password is
* Easy to use
Feedback:
The most of people who encountered with SQL 2005 password losing problems are getting back to their SQL account now. We can also feel that ease and the hilarious mood when a hard nut has been cracked. Hope this MS SQL Server Password Unlocker would help more people and get their trouble erased.
on Nov 12, 2010 | Computers & Internet
I replaced logic board unlocked but their is password.how can disable .
So you bought a logic board and when you installed it, it already had a password set on it? That means the logic board was not new. Take it back to the Apple iStore.
You can clear it by connecting it to iTunes on a computer and do a factory reset.
Dec 26, 2015 | Apple iPhone 4S
How to unlock my lg optimus logic straight talk p
Should be able to just touch the screen and slide up unless you have a password or a specific type of security in place.
Jun 21, 2014 | Straight Talk LG Optimus Logic Cell Phone
Wont turn on
try to reset the device using a paper clip to press the reset button located on the side of the device case.
here is a link for the user manual http://d1h33o57i1sehj.cloudfront.net/TNDRestWebService/Manuals/IntelliRoute%20TND%20710%20User%20Guide%20Version%202_0_1.pdf
Sep 09, 2012 | Rand Mcnally TND 710 GPS Receiver
I have an Acer laptop with windows vista. I've forgotten my logon password. Can you help?
just download and make a cd boot from cd .
click here
Click here
or another
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd
DONT PANIC follow all the steep It is very simple ,
Use the down arrow key.
1.INSERT CD TO CD TRAY
2.Boot from cd
FOR PASSWORD BREAK
3.Select start boot cd
4.Coice Password and Registry Tools>enter
5.Choice Active password Changer for (NT/2000/XP/2003/VISTA)ADMINISTRATOR PASWRD RESET.
If you change the HDD PASSWORD, Seclect ATAPWD 1.2(HDD password Uttility)
wait >all will be AUTO
HERE YOU can see the option 1.Logical drve and 2.Search for all HDD and logical.
If you have one HDD choice 1. Logical drive
You you Have More then One Choice search for all hdd.
Just Choice the no and put it on the Your Choice [ ] >enter
Now Choice the partition
Either "0" or "1" which is your active partion for your Opereting System. If you have two "OS" in the same HDD,
should choice all.
If you have one "OS" choice "0" to "1" press the number .Generally would be "0"
Only the reason, every laptop has the option ,for one HDD.
So Choice "0" >enter
Follow the steep on screen text > enter
From here, you can see the option for Administrator or Usser .
Generally Administrator will be "0"
Hope it will you.
Jan 05, 2011 | Computers & Internet
JVC C-20710 TV 20" Does anyone know where to find the operation manual.
ABL is the problem of your tv.it is a resistor near tha plyback.
Oct 14, 2008 | JVC C-20710 20" TV
ETL Secure Logic 20710 Keypad Wall Vault Logo
111 people viewed this question
Top ETL Home Security Experts
Lawrence Oravetz
Are you an ETL Home Security Expert? Answer questions, earn points and help others
