Wet line on ceiling between 2 air vents that runs about 8 feet
We have a wet line between 2 air vents that spans about 8 feet. I have no idea what is wrong. Any ideas are welcome!
  • 10,865 Answers
I would begin by inspecting and repairing the flashing around each vent. Generally you can use a caulk gun with a tube of roof cement for this quick repair.
Posted on May 17, 2009
How many 2x3s are needed for ceiling 10'x11'
First of all we need to know is the two by threes inches or feet on your ceiling 10 x 11 ft you need to square it 10 times 11 divide whatever your two by threes are into the feet if their feet goes into feet you're okay if not you'll have to take change the two by threes two feet or the 10 x 11 to inches in that's reasonably simple if you know your math
Oct 27, 2017 | Computers & Internet
Tip
Air Flow-Life of Equipment
One very important DIY maintenance detail we may forget, or totally ignore, is our air filters, fan, dryer vents, and many other items needing good air flow. Most of us are pretty good about changing air filters in our furnace. The dryer vent can really cause a lot of damage. So not only do we want to clean the obvious lint trap, we need to inspect the hose, and follow it to the outside of the house. Moisture traps the dust inside the pipe and outside vent. Air conditioning/Heat wall units gather a lot of dust as well as window AC units. When you see air intakes, there is usually a filter that will need regular cleaning. Some are reusable you can vacuum, or wash with soap and water. If you do the later, make sure the filter is totally dry before replacing. Every 6 months I move my Fridge away from the wall and vacuum the dust behind where the compressor is so it will run nice and smooth. The big jobs, like cleaning the dryer vent to the outside, is more of a yearly job where as others are monthly, or 3 months. Even your hair dryer has a place where the fan runs, that can get totally clogged. An old toothbrush usually takes care of that. Never put water in anything like a hair dryer, you could damage it. I hope this little tip helps you to remember Air Flow, is so important to all of your items that need a good steady stream of air
on Dec 08, 2011 | Kitchen Appliances - Others
WHAT IS THE SQUARE FOOTAGE OF A 14 BY 70 MOBILE HOME.
Hi Sharee:
The square footage is 14 times 70 equals 980 square feet.
That would be the Floor Area.
Air conditioners sometimes need to know the building volume so if you have 8 ft ceilings you would multiple 980 by 8 to get 7,840 CUBIC FEET.
Air exchange is typically are rated at cubic feet per minute and required as "specified Air Changes per Hour.
An example for your trailer would be 1/2 air change per hour required per building code. 7,840 times 1/2 equals 3920 cubic feet per hour. Divide that by 60 to get 65 cubic feet per minute.
That would be the minimum air change capacity for your air conditioner if it was also providing required ventilation.
May 17, 2015 | Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
Poor air movement
mcdevito75 here, You say the fans are recessed into the ceiling are the fan blades blowing the air into this recess instead of outward. Also if your porch is an open porch the fans are competeing with the outside air and temerature. The only other thig to try is to lower thefans another foot.
Jul 27, 2010 | Hampton Bay 52 In. White Huntington III...
I have a 2006 victory vegas 8 ball w/ 900 miles on it. It has never had a problem staying started. For some reason now, i turn it on it stays running for about 3 seconds before it stalls. The air filter is...
Hi, Thomasyu2004 and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike wont run past very low idle She dies when you give her gas
2006 8 ball idling issues
http://www.granitestatechapter.com/mydata/05-06%20Hammer_06%20Jackpot_Service_Manual.pdf
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Victory Motorcycles 2005 Vegas Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 30, 2017 | 2006 Victory Vegas 8-Ball
What is the maximum length of exhaust venting that one can use
According to the manual the longest run of pipe that can be used is 78.7" (6'6.7"), but the maximum termination height is 51.2" (4'3.2"). Hope this helps
http://www.delonghi.com/delonghi/data/int/usa/libretti.nsf/d43b2a60086dfe93c1256a47004ad1f5/37974a66fe82678885256f1200671bfa/$FILE/CF210.pdf
Jan 18, 2010 | DeLonghi CF210 Portable Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Wet line on the ceiling between 2 vents
You have a clogged condensate drain line and the condensate is now being syphoned up by the blower and coming out the duct work.
Find where the condensate drain exits the house and you can back flush it gently with a garden hose. Then clean out the condensate pan and pour a mixture of warm water and baking soda into the pan down the drain.
May 17, 2009 | Heating & Cooling
Lint bypassing lint filter and water in vent transition hose
your hose is to long you should vent it stright out wall if you can't you can buy a small inside vent kit it take so long to dry becuase it's not exsusted proper
Jan 27, 2009 | Maytag Neptune MDE6800A Electric Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
