Question about Alesis Q25 25Key Keyboard Midi Controller
Alesis q25 doesn't work in windows 8
2 Suggested Answers
  • 97 Answers
SOURCE: manual,I need manual for Alesis Q25
Go to : http://www.alesis.com/q25?tt=5 and click on the docs and downloads as shown in picture below. There you will find the pdf documents you are looking for.
Go to website address:
Posted on Apr 04, 2013
Manual,I need manual for Alesis Q25
Apr 04, 2013 | Alesis Q25 25Key Keyboard Midi Controller
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I AM LOOKING FOR A N ALESIS 8 CHANEL MULTIMIXER THAN CAN BE USED WITH 220V
Since this unit uses so little power, I would recommend a small stepdown transformer. A 20 or more Watt one is sufficient. DO NOT use a convertor that is intended for appliances like hair driers.
Here is a link... the smallest would work and costs $8... I don't know how they can make them for that. You might consider getting a bigger one if you get other equipment to run as well.
Finding the special power adapter that uses 220 and is compatible to the Alesis would cost much more.
Mar 14, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
Alesis SR16 will not work. 8 blocks of blacked out spaces at the top row when starting. Lines appear where they should on screen but the machine does nothing. Any ideas? Tried the "erase and play...
First thing is to check the power adapter. Make sure it is the original and is producing correct voltage. There is probably a memory backup Lithium battery in this which may be depleted.
Also do a factory reset on the unit. Try this: Power off...then power up while holding down "play" and "erase". Worst case you may have to find another working SR16 and transfer the data from it to reload data.
Jan 08, 2011 | Alesis Sr 16 Stereo Drum Machine
The display does not work. The sounds are still
The LED Panel is dead.
Alesis has a parts company that they can refer you to for the proper LED panel. Price is high, however.
Contact Alesis 401-568-3131 or NuMark for the Alesis contact info. I was able to find QS6 and QS8 parts through this resource.
Jun 07, 2010 | Alesis Sr 16 Stereo Drum Machine
How do get this machine to do 3/4 time?
go in and create your own pattern, set the time signature to 6 beats per measure
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link:http://www.squest.com/Windows/Instruments/AlesisSR-16/index.html This link might also be useful:http://www.synthzone.com/alesis.htm Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Q25 25Key Keyboard Midi Controller Logo
18 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
