Question about RCA RT2870 Theater System
RCA RT2870-A powers on for about 10 seconds then shuts off
How to connect the RT2870 to the pre amp out ?
Since the RT2870 doesn't have and preamp outs, to WHAT are you referring?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2870-Home-Theater-Systems-manual/id/23608dj493/t/2/
Any external device that provides a fixed or variable (preout) Line Level signal could feed either of the RCA
Mar 30, 2011 | RCA RT2870 Theater System
I have an RCA RT2870 Home Theater System When you power it on it comes on but if you switch from one source to the other the system will shut off. Like if you switch from DVD to AUX or if you try to eject...
firstly can you tell me where you have the scart connected too it should be running into tv/scart secondly check or replace scart could be faulty check all wirering codes to and from soun system goodluck
Mar 18, 2011 | RCA RT2870 Theater System
I'm having a problem with my RT2870 RCA Home Theater System. When I plug a USB turntable into the USB slot, it will not recognize it. It does however, recognize MP3 players that have a USB slot. Can you...
That's because a USB turntable is a bit higher up the compexity foodchain than a USB drive with files already on it. The RT doesn't support anything but USB devices that mimic storage devices.
Register and download the user guide for free at retrevo.com
Mar 05, 2011 | RCA RT2870 Theater System
How do I select the FM band on a rca rt2870
press the am/fm button onthe remote or recivier
Mar 12, 2010 | RCA RT2870 Theater System
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
When I turn my unit on, it will turn itself off in a few second.
have you checked to see if any of your speakers are shorted out? the rt2870does have a self protection system in place such that if theres too much power being drawn from the system or if a short occurs it will shut off. or the switch that powers the sub may have gone bad so try disconnecting the sub and see if that helps. i have the same system and i had the same problem and i had to replace the onboard sub-woofer power switch.
Mar 15, 2009 | Audio Players & Recorders
Rca rt2870 doesn't work
My RCA model #RT2870 subwoofer doesn't work but the sub light is on... HELP!!!
Jan 18, 2009 | RCA RTD260 System
RCA RT2870 Theater System Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
