Question about Daewoo Washing Machines
What does LEP mean?
What type of detergent is needed?
Facebook - Playdom games
Sometimes it may be that the game has been moved to a different location, or it has been withdrawn, or too many people want it at the same time. Get in touch with Facebook Support
Apr 29, 2014 | HP Compaq Presario SR2032X PC Desktop
Can't open certain games anymore on Facebook.
ask FBook this?
no pc stated, no os.stated
no browser stated
strike 3, you be?????
Jul 10, 2017 | HP Compaq Presario SR2032X PC Desktop
Type oil compressor
non detergent 30w
if you mean what kind of oil for the pump
if not, what do you mean ???
Dec 11, 2013 | Ingersoll Rand - Rand Type - 30...
Samsung washer error code f1
What kind of detergent are you using? F1 in most cases means that the wrong type of detergent is being used. If it's a front-loader, you should be using h3 detergent.
May 21, 2012 | Samsung Clothes Washer Power Control Board...
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Error code
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use minimal amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
What does Sud mean on the washer machine
Typically it is indicating there are too much suds in the machine for it to operate effectively. i.e. too much detergent, wrong type of detergent, or a load of soap filled towels etc. Rinse the unit out via a "quick wash" cycle without any garments in the machine and try again...using "HE" detergent, or less of the detergent. DO NOT use non-HE no matter what sales people or friends have said. It is the great destroyer of tub bearings, clothing and just all around BAD. Good luck :)
Sep 25, 2009 | Kenmore Elite HE5t Washer
Suds Suds Suds
The SUDS fault indicator is caused by using too much detergent, or the wrong type of detergent. The Kenmore Elite front loaders were designed to use HE type detergent only. When the washers first came out, manufacturers originally made the claim that you could use regular detergent if you used less of it. The manufacturers later retracted that claim because there were a lot of problems with over-sudsing. If you are not using HE detergent, you need to be. In the mean time run your machine with no load with hot water to clear the drum and drain lines of any soap residue. You may have to do this a couple of times to clear the problem. I hope this helps.
Mar 31, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
