Question about Food Mixers
Remove beaters from mixer CAMFIELD MODEL NUMBER 70 SM 6 CH 10 SPEED POWER MIX
  • 3 Answers
SOURCE: replacement beaters
See solution for Euro-Pro EP546 replacement beaters. Call them at 800-798-7398.
Posted on Feb 06, 2008
  • 20 Answers
SOURCE: Replacement beaters for Hamilton Beach Hand/Stand Mixer Model 64586
Call the factory. they will point you in the right direction. number online!
Posted on Apr 11, 2008
jerryg50
  • 1667 Answers
SOURCE: lost beaters
Toastmaster factory parts
http://abtecparts.com/toastmaster.htm
Jerry G.
Posted on May 29, 2008
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
I called west bend about mixers for my stand mixer.Model number 41036. They said this model has been discontinued and they could not help at all!!!
Posted on Oct 20, 2009
Proctor silex hand mixer, brand new, just out of box, worked fine for quick on/off test, and then...NOTHING. Wont turn on?? Store is closed until tomorrow, I NEED it for what hv to cook tonight!!
Are the beaters installed? some of the newer ones require the beaters to be inserted fully. Try unplugging from the wall then remove and re-insert the beaters. Then plug it back in and try it.
If not, it might be the motor. These are very inexpensive($12 on amazon) and are known for problems. I would plan on buying another and returning this one if the beater thing doesnt work.
Oct 16, 2016 | Proctor Silex Easy Mix 5-speed Hand Mixer...
I need beaters, model no. Pm581-1 for my Westinghouse hand mixer. It is older than 10 years.
look on line or a small appliance repair /shop for replacement or universal unit that fit your machine
Oct 11, 2016 | Westinghouse Westingtinghouse 3-speed Hand...
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
Wont mix motor euns beater skips
This will be caused by a stripped gear. However there are several gears that may have stripped and you will need to take the mixer apart and inspect the gears.
I would need the model number of your mixer to determine what parts you would need.
Thank you,
Colleen
MendingShed.com
800-339-9297
Jan 19, 2013 | KitchenAid Food Mixers
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
Canot take the beater out of the mixer.when I have mix my my cake I cant get the beater out to clean the beater.
counter top appliance number for kitchen aid is 1-800-541-6390 M-F 8-8 EDT, and Sat 12 -5 p.m.
Oct 21, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
