Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser combination lock for front door
Have had this lock for 10  years.  have used the same combination for that length of time.  decided to change it by imputting 2 new codes as it is a 2 code lock.
Well, it now opens with all 3 codes.
Is it possible that I put the first code in 10 years ago thinking it was changeable and it is a Master Code?  If so, how do I change it as every repairman in the area has it on his entry list.
    President:
  • 704 Answers
You can reset the lockset to change the master code and then enter in other codes for use by contractors, delivery people, etc. which you can then delete as you wish without having to give out the master code.
Rather than give you the simple step-by-step instructions for resetting the lockset, I've provided a link to the user manual so you can have it available for use and reference, as I assumed you didn't have yours any longer.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
  • 10,865 Answers
If this is the master code you can not change it. You can either replace the entire lock or call a lock smith shop to see if they can change the master code.
Posted on May 17, 2009
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to change the combination on weiser lock
Follow this link:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Which will take you to the programming instructions for your Powerbolt 1000.
Jun 27, 2011 | Weiser Lock Powerbolt 1000 Lock
The lock does not retract all the way in when you enter your code, it seems to get stuck half way so you cannot open the door???
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
Nov 29, 2010 | Weiser Lock Powerbolt 1000 Lock
Weiser has a one year warranty against electronic malfunction and a lifetime warranty against mechanical and finish problems.
You can review it and contact them for further assistance from this link:
http://www.weiserlock.com/CustomerService/WarrantyInfo/Powerbolt.aspx
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
May 02, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Jan 07, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
1,732 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
