Question about Dewalt Heavy Duty XRP 1/2" 14.4v cordless hammerdrill/drill/driver kit - DC984KA
I want to remove and replace a damaged chuck trying to remove t15 screw from chuck turning clockwise and the t15 bits break under pressure also tried spraying wd40
  • 163 Answers
It a backwards thread. I think you turn it to the right to loosen.
Posted on May 17, 2009
Removing chuck
You don't say which drill you have, but this is one method.
Remove the left handed screw from inside the chuck, put the drill into low gear then lay the machine on it's left side, fit a suitable spanner on to the slot behind the chuck and arrange it so that the spanner is against the work surface. Put the chuck key into the chuck and give it a hard blow so you knock it in an anti clockwise direction. If it is a keyless chuck or you don't have a key try holding the short end of a large allen key in the chuck and knock the long end in a anticlockwise direction. This will work even if you don't have a spanner to fit behind the chuck but you might have to hit it harder. If you have a vise after removing the screw hold the chuck in a vice and fit the spanner behind the chuck and turn it anti clockwise.
Jan 03, 2013 | Makita Drills
Makita bhp453 chuck screw wont loosen
The chuck screw on drills is put in with lok-tite and is reverse threaded. You need to get the screwdriver on it firmly and turn it clockwise, as you are, with strong, constant pressure until it breaks free. Don't let the screwdriver slide out of the screw slot, if you round off the screw head you'll have to cut the chuck off. If it still won't break free, try putting the drill in a vice or use a screwdriver with a hex nut molded into the driver shaft so you can use a wrench for some more torque.
Mar 11, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Need to know when removing a chuck from a drill is it clockwise or counterclockwise?
The retaining screw at the bottom of the chuck ( down inside where you put the drill bit) is reverse thread. the chuck itself is regular thread. Take out the retaining screw, chuck a 3/8 inch allen wrench ( short side) into the chuck just like a drill bit. Lay the drill down on a work bench with the chuck pointing towards you and the allen wrench clear of the table. Hit the allen wrench with a hammer, ( may take a few tries) in a counter clockwise direction. the chuck should unscrew.
Nov 17, 2010 | Milwaukee Tool Drills
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
Am trying to remove a drill chuck head please help.Its a black and decker drill
Open the jaws all the way, inside there is a Left handed screw, meaning you turn it clockwise to remove it. With that out the chuck unscrews counter clockwise, You may need to put the short end of an allen wrench in the chuck and then hit the allen wrench with a hammer/mallet to break it loose. Reverse to reinstall
Mar 28, 2009 | Drills
Removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Nov 24, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck replacement
Hi Paul with the screw out you will have to lock the short end off a sturdy allen key in the jaws off the chuck then sellect first gear on the drill then with a hammer hit the long side off the allen key so that the chuck unscrews normal thread (anti clockwise) the shock off the hit will free the chuck.
Hope this helps.
Sean.
Apr 02, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt Heavy Duty XRP 1/2"  14.4v cordless hammerdrill/drill/driver kit - DC984KA Logo
103 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
