Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Power supply no good
I, need a new power supply for a D-link Router, power supply model #MI-12S05. power sup input 120 v, 60 hz output:+5.0v......2.5a... iwould like to know where to purchase one
    President:
  • 623 Answers
That mainly depends on where you live, but you should check places like RadioShack, Bestbuy, or the local Electronic store.
Also try a shop which sells Cell phone accessories and parts.
120V/60Hz is standard in the US. The numbers you have to watch are theoutput: You will a voltage of 5V and the converter has to be able todeliver 2.5 Ampere (that's wnat your router needs).
If you go out and get a converter make sure that the plug fits yourrouter! As you know, there are 5 million different plugs and what mightlook like it fits, sometimes doesn't. Take your router with you toensure it is working. If you get one without being able to test it,make sure you can return it in case it doesn't fit.
You can also try e-bay (look what I found here).
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 17, 2009
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
What is the inside of a d-link power supply?
Mi pc no enciende, nofUNCIONA nada mi es MX36LE-U
Since it is a socket 370 motherboard I doubt it draws a lot of power no matter what kind of AGP video card you have in it. Your board also only has a 20 pin connection for its main power to the motherboard. So that being said I would pick up the Rosewill RV350 power supply for your computer. I have personally installed several of this very make and model for people and have never had one die on me yet... Here's a link to the very power supply you need and I think it's even on sale right now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182006
May 17, 2012 | AOpen Computers & Internet
Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Aug 12, 2009 | Samsung Televison & Video
I have a whirlpool washine machine and i need to find a sup unit in the machine? can you tell me where this is in the machine?
Sorry, I have never heard of a "sup" unit, unless it is short for supply.
Below is a link to a parts page for your washer. The diagrams are on the left, you can click on one and search the parts for what you are looking for.
Hope this helps, good luck.
Regards,
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140186
Jul 18, 2009 | Whirlpool WFW8400TB Front Load Washer
D-Link DIR615 power light doesn't come on when plugged in
You must have checked in the first place the voltage input of the router. Some router use 12V and others use 9V. Now if you have supplied an incorrect voltage input, you might fry the router's main board. Double check the voltage input of the router first vs. the adapter's output. If they are on the same voltage, your router is dead already
May 09, 2009 | D-Link DGL-4500 Wireless Router
Emachine t6532 motherboard issue???
Is your new SUP has the same specs with the old SUP? like voltage output, WATTS etc....
Usually motherboards have a led light in it that will light up when its connected on SUP.
regarding the wire placements for power and led connectors, you can view it in your users manual.
Feb 05, 2009 | E-Machines eMachines Desktop PC
Installing a DI-524 router
Hi askar,
I'm assuming if you've been given a username/password you've either got DSL (a PPPoE connection) or it's for your email address. If you don't have a disc for your new router, you can configure it through a wired connection to the router (using an ethernet cable). That's a bit of work but if you need to do it that way we can help. Otherwise run the CD that came with the router (again, you'll need a computer plugged into it) and the step-by-step should get you through it.
For starters, unplug the modem and then plug the cable running from the old router into the same port space in the new router (should say either WLAN or Uplink). Turn on the modem, wait 30 seconds, then power on the router. After that run the disc and you should be good.
If not, let me know!
Ben
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
129 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
