Question about Husqvarna Viking 1
Viking Sewing Machine
My bobbin thread keeps breaking. I rethreaded everything and noticed that the thread coming from the bobbin was very tight so I loosened the bobbin screw but it is still hard to pull through. I blew out all the fiber dust and loosened the screw some more but still tight and I noticed that when I was sewing the bobbin thread was lying flat and the needle thread was doing all the looping which indicates the bobbin thread is too tight but I have the bobbin so the tread is way looser than it is suppose to be.
  • 290 Answers
Be sure you haven't missed a loop while threading the bobbin. If that's not it, check how well the bobbin is turning on the spindle. If it is threaded properly and you have cleaned it, I suspect you will find some damage to the bobbin that is causing it to bind on the spindle. If you have another bobbin, try it and see what happens.
Post back to let me know what you find.
Posted on Oct 19, 2007
  • Michael  Lindley
    Michael Lindley Oct 21, 2007
    Just wanting to follow up on your sewing machine and see what you found.
    Thanks/Mike
SOURCE:
My Janome 1600 keeps breaking threads
Is the tension too tight? Are the tension discs clean? Remove bobbin case, clean it and re-thread as this may be jammed.
Apr 26, 2015 | Janome 1600P-DB Mechanical Sewing Machine
Thread keeps breaking
change the needle
rethread the machine top and bottom
make sure the bobbin is wound correctly and inserted correctly
make sure the are no burrs on the needle plate or in the bobbin area
make sure the thread tension is not to tight
Apr 24, 2015 | Kenmore Sewing Machines
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
Why does my thread keep breaking on my machine while i am sewing
the top tension could be to tight
the needle could be damaged
try rethreading the machine just in case the thread is caught somewhere
clean under the needle plate & bobbin area for lint or loose threads
always make sure the top & bobbin thread tails are at least 3 to 6 inches long & pulled behind the needle to the back of the machine
Aug 29, 2011 | White Sewing White 3032
Needle severs thread each time I start sewing
Take the thread completely off the top of the machine. Put in a new needle. Remove the bobbin. When you rethread the top of the machine make sure the presser foot (that rests on the fabric) is in the "UP" position and rethread the top. Also when you thread the top, put some "pull" on the thread as you thread it, don't just lay the thread in the tracks. You need to pull the thread with some taughtness through the machine so it gets into the correct places under the covers so you have good tension and good stitching. Then put the bobbin back in and make sure when you thread the bobbin case that the thread "clicks" slightly as you pull the thread into the metal tension area of the black bobbin case. Anytime a sewing machine breaks thread at the needle, you should unthread the entire top and rethread it because the thread can jump out of it's guides that are under the plastic covers and you won't be able to see it, but you will see very ugly stitching!!!
Nov 19, 2009 | Husqvarna Sewing Machines
Machine not working
I had this happen the first day I got my machine. The bobbin case has probably came loose from the holder. There is a step by step cleaning instruction in the manual and it tells you how to reset the bobbin case in the holder in the manual.
Nov 15, 2008 | Husqvarna Viking 1
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
63 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
