Question about Monster Cable GreenPower MP HDP 900G 8-Outlets Surge Suppressor - Receptacles: 8 x AC Power - 3240J
How do I reset the cable after power serge
How to reset after power serge
Canon MG6100 printer not responding. There was a power serge earlier in the day. Computer and printer both have power and have been restarted.
Delete the driver from your system then go onto Canon and download a new up-to-date driver
Trust this helps
Sir Dana Taylor
Apr 22, 2017 | Canon Office Equipment & Supplies
Power went out and tv not working. do I plug back in holding the on/off switch
Try a reset and if it does not work, has to be open and check power supply board and the other boards. Good luck,
Serge.
Feb 16, 2016 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
My 95 accord with 4 cylinder is flashing code 14 IAC valve i replaced the valve but car still serges and code still flashing 14
did you reset the code? have you tried removing the battery cable and waiting 5 minutes?
Jun 08, 2015 | 1995 Honda Accord
Have power outage now not cooling
i know this is probably to late to help you but if you have a power serge most likely it took the mother board out,the new boards come with a serge protector most common board ir wr55x10942,everthing on this machine runs through the board.hope this helps
Oct 16, 2014 | GE Refrigerators
Printer shows no cartage found
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
May 11, 2010 | HP PhotoSmart C4385 All-in-One Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
-Serge
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power serge
How do you make the amp come back on after you change the fuse
Oct 25, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Monster Cable GreenPower MP HDP 900G 8-Outlets Surge Suppressor - Receptacles: 8 x AC Power - 3240J Logo
342 people viewed this question
Top Monster Electronics - Others Experts
Are you a Monster Electronics - Other Expert? Answer questions, earn points and help others
