Zenith model number Pdp50t10000 power supply eax61397101/10 p/n eay60968701 I have no picture I have 4.8 volts going to Y sustain and 5.1 going to control board think its call
I can add more details just trying to figure if my set is dead or is it the power supply or buffer boards/y sustain boards and I am getting my standby voltage
  • 231 Answers
SOURCE: sony tv model klv-32u100m dead standby 5 volts ok
most probably is (a) board ..very common on these models.These boards are made by RoHM.These are similar and used in maganvox,philips and others..Very common breakdown
Posted on Nov 30, 2007
zjut
  • 106 Answers
SOURCE: Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Posted on Jan 05, 2009
SOURCE: RE: Dell W4201C
i have a Dell W4201C ,the picture Dims or picture blinks when channel changes
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: p50hdtv10a y-sustain and pcb
I had this problem with a different brand plasma and it turned out to be cracked or missing solder on the power board lead to y sustain. I removed the power board, desoldered the connection, clean it up and then resoldered the connection. Everything works great now.
Posted on Sep 27, 2009
ginko
  • 19396 Answers
SOURCE: how do I test the y-sustain main board from a
Hi.
As such boards are cheap and fail quite easily (both the two sustain and the buffers) Philips service manuals are more oriented at board swapping then at proper testing. In this particular case the buffer boards fail very easily because of a bad soldering to IC. The short will regularly blow the main sustain board.
To start when a main sustain (e.g. Ysus) is fried the TV will go in protect mode with the led flashing in standby. One test is done disconnecting the Sus board (with power off) and restarting the TV. If TV does not go in protect, then the sustain board was good.
If there is no protection:
The first thing to check on a main sustain board is the fuse. If the fuse has blown the IC is probably fried.I believe fuse is F5004. Check for swollen capacitors that may have blown. Test the FET. That is the core of the board as it is the power amplifier.
Here the service manual:PHILIPS_SM_15540.pdf - Right Click "Save Target As"
Here a more useful service manual. Check and follow troubleshooting diagrams in manual.
Here some troubleshooting from users.
Note:if buffer board was shorted, then the main sustain board is usually faulty.
Regards.
Ginko
Posted on Sep 13, 2011
Power but no picture black screen
You should start for the Vs & Va voltages itself. The details to these voltages will be marked on the panel label itself. These two voltages should be more specific than other voltages, especially to Plasma displays. More variations; say; + or - 1%, can effect the display drastically. To get more details about this, you have to download the repair manual to this set, and refer its schematic diagram. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 25, 2013 | Televison & Video
Zenith z50pg10 its dead no click, no led blink nothing !
Zenith Flat panel TVs usually only have two boards in them Plasmas have a few more, doing a visual inspection of the power supply capacitors usually reveals swollen or bulging capacitors.
If the capacitors look good, voltage checks would be needed to isolate the problem to either the main board or power supply. Check for 5 volts to the IR board (& or keyboard) , if five volts is present suspect the main board
If this TV has voltages from power supply , suspect the Z, X and buffers
May 26, 2012 | Televison & Video
I have a 25" Zenith
You will need to replace 4 capacitors. Locations and values are C 3460 which is a 25 volt 220 Mf capacitor, CX3218 at 160 volts at 1 Mf (could be 2.2Mf), C3416 at 25 volts 100 Mf , and CX 3413 at 50 volts 22 Mf. In severe cases you would also replace the powerling regulator,(STR-53041) I don't think you need to in this case. Now the green spot you speak of may be the need to resolder the thermistor. I don't recall the exact location. It is a small disk located on the edge of the main board near the power board connection( Your 110 power cord to board). I also believe there is a glass fuse near by. This is a two legged disk that is silver. Take care when soldering this. If it does break you may replace this with an RCA part# 207768. And lastly, when replacing the board back into the TV, make sure you have a good connection to the CRT with the suction cup. It should be tight fitting with no air to escape! Thanks for asking and show a few hands of support!
Mar 27, 2011 | Zenith C25A24T TV
Sound works picture doesnt. what should i look for
Make sure you have VS and VA voltages from the power supply to the Y main and the Z sustain modules. If they are present then check for 5 volts and 15 volts to turn the modules on. Those can be found on the power supply module.
Feb 05, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Zenith Projection Tv Set Model number ZB4685T no Visual
Since this is a CRT based set, there could be a number of problems. What exactly do you mean when you say that the picture fades? Do you loose contrast and the picture gets lighter? or does the picture darken toward black?
Parts are still available, so this can be fixed. If youfeel you want to attempt this yourself, please supply additional info and we'll walk down the diagnosis path.
Dan
Aug 08, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith PVY6067DT Starsight - 1996 No Picture No Sound
i just bought one of these with the same problem and had a repair man come over. said it has a h.v. power supply problem even though the red light is on and some little board cant read the handwrighting on estimate but will follow up. must replace the whole board the power supply sits on, it is the big board that the power cord connects to in the back of the tv... other board it is located behind the little panel in between the speekers on the front it is the little one in the left hand top corner. parts/labor mainly parts +/-$500. is it worth it? ihave not seen this tv working so if there are any comments about the picture quality i woul like to hear/read them. hope this helps.
Oct 11, 2007 | Zenith IQB50M90W 50" Rear Projection...
Old zenith intermittent power on problem
would need a model number and if it that old wouldn't advise in fixing it.
Oct 10, 2007 | RCA F27442 27" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
