Question about Health & Beauty
I have the wahl clippers model CMCO and I can't get them back together
2 Suggested Answers
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
Wahl clippers
Have you read the instructions and put it together the right way?
Sep 29, 2013 | Wahl Home Grooming Animal Clipper Kit With...
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
I took the bland off of my wahl model 9860-1101. And the pin spring came out and I don't know how to put the pin sring back in. How to I put it back together?
Your best bet is to send it to www.mannyssharpening.com Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 13, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Jun 08, 2009 | Wahl 8550
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
