Question about GE Profile Spacemaker PVM2070DMBB 2.0 cu. ft. Over-the-RanMicrowave Oven with 1100 Cooking Watts, Dual-Distribution Cooking System, Recessed Turntable, EasyGuide Menu System, 315 CFM Venting and HaloLightinBlack
GE microwave PVM1790
The microwave will not shut off unless you unplug it
MicrowaveSvc
  • 9098 Answers
SOURCE: Spacemaker II Microwave problem
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
kel1guy2002
  • 3740 Answers
SOURCE: Same problem that was asked recently. I didn't
I have to ask. Have you tried to see if the magnetron was also running at the same time as the fan and turn table? The reason I ask is.... "usually"... all three are energized at the same time. Try a cup of water inside to see if it heats up when time has run out in addition to the fan running and the turntable turning.
These functions are controlled by the relay PCB
Item number 1653 of the link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5225881&diagram_id=24680726#d24680726
I am not saying the relay PCB is bad... but something is telling the relay PCB to remain energized via the Smart board Item 1655 of the link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5225881&diagram_id=24680724#d24680724
Either one can cause the problem and I am not going to sit here form the computer and tell you to go buy either one. They will have to be isolated and tested with a meter.
If you were to change the replacement parts listed above the total (parts only) cost is over $200.00.
There isn't alot you can do without a service manual in hand to troubleshoot this one. Maybe a few... taps on the relay PCB.... after that.. it is test probes and meter time.
Kelly
Posted on Mar 09, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Space,aker 1800 microwave is making
You should keep it unplugged until it's fixed. If it's cooking while it should be off, that can damage the oven or even start a fire.
It's either a failed door switch or door switch mount, or a bad electrolytic capacitor on the control board, which we can repair for $39.95.
If you're hearing a fan or motor running, I'd suspect the switch. See this file for help.
If it's a buzz (like a power line buzz) then I'd suspect the board capacitor.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
heatman101
  • 43501 Answers
SOURCE: Jvm1870sk04 GE profile microwave will not shut off
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 20, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge microwave just runs. It will not stop
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 03, 2010
GE Profile microwave PVM1790 starts, what I believe is an internal fan, when I open the door. I sure hope it's not the microwave component frying me.
You probably have a defective door switch, or a bad relay. You are not being microwaved. It would blow its internal fuse to prevent that from happening.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 16, 2017 | GE Microwave Ovens
Microwave wii not shut off unless you open the door and sometimes starta when you shut the door.
Sounds like one of the door switches is shorted. Check all three for proper operation with power off. WARNING: Microwaves contain lethal voltage levels can be more than 4000V, more then enough to kill you! BEFORE doing an work on them, unplug from power and discharge the capacitors. If you don't know what you're doing its better to leave it alone and get it professionally serviced.
Feb 27, 2015 | GE Profile Spacemaker Over-the-Range...
My ge microwave model # jeb1095sb03 shuts off after 1-2 seconds
Hi Bruce,
i think power supply problem,maybe loose contact of jumper wires or loose connections of PCB.
go for repair center,
regards,
nuwan
Jan 12, 2014 | GE Microwave Ovens
The dial selector on the GE Convection/Microwave PVM1790 is pushed to set the selection. After two months, our dial selector "sticks" and requires a hard push (or two) to enter the selection. I...
Dont play gemes with it, or it will cost you a lot of money, Get GE out to repair it. Those dial controlls can be dificult so since it is warrantied get it replaced, it shouldnt do this to you this soon. They will probably have to replace the whole main Circuit Board, Timer Board.
Sep 28, 2017 | Microwave Ovens
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650WB008 Microwave. Daughter used left
probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
Our advanium is only 1.5 years old. Now it will
I cannot find a recall But you should contact the distributor and have it rectified
Aug 15, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Microwave Oven would not shut off even when the door was opened. We unplugged it and plugged it in later and now it seems to be OK. What happened?
Hi, the contacts in the micro switch or relay proberbly fused together. Do not open door if is still on unless you want to cook yourself
Aug 04, 2009 | Microwave Ovens
GE Microwave
maybe the problem is in the door latch switch try to replace the switch going to lights or bulb.
Jun 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker PVM2070DMBB 2.0 cu. ft. Over-the-RanMicrowave Oven with 1100 Cooking Watts, Dual-Distribution Cooking System, Recessed Turntable, EasyGuide Menu System, 315 CFM Venting and HaloLightinBlack Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
