Wet line on the ceiling between 2 vents
When I went to bed last night, I looked up and noticed a wet line going between the 2 vents in our master bedroom. The vents are about 8 feet apart. We are the only owners of our house that was built in June of 2002. I am thinking that maybe there is a problem with the ducts in the AC since it is from vent to vent. We have an amana prestige 2 unit. I don't know who to even call about this problem. Any ideas of what it might be or who can help? Can my husband and I fix this problem ourselves? Thanks!
    Guru:
  • 1,524 Answers
You have a clogged condensate drain line and the condensate is now being syphoned up by the blower and coming out the duct work.
Find where the condensate drain exits the house and you can back flush it gently with a garden hose. Then clean out the condensate pan and pour a mixture of warm water and baking soda into the pan down the drain.
Posted on May 17, 2009
My ABS light came on last month ,3 weeks ago pedal went to floor,than week ago ,than last night . fluid an pads are good
Master Cylinder is leaking past its seals. As for abs, could be related or separate issue.
Jul 27, 2015 | 2001 Chevrolet Malibu
After minor front end accident damage. Brakes won't fungtion, almost no brakes and pedal bottoms out. Changed master cylinder an bled brakes with no improvement to problem. Engine vacume nine lbs.
was it a new master cylinder or a old one?' under the master cylinder is a load sensing equalising valve its a 136 euros piece of spare part new is this ok or was that damaged in the accident ,iam going to bed had a late night on a breakdown last night and then up early so iam a bit tired to think straight sorry
Aug 25, 2011 | 2001 Daewoo Lanos
Not cooling off my room
Check your filter to make sure it is clean, if not replace it.
Make sure at least 90% of the vents are uncovered.
This will ensure you are getting proper airflow to the coil. At that point if it is still doing it, and all the fans are running properly, then you either have a dirty coil or low refrigerant charge.
Check the temp coming out of the vents, and the temp going into the return. It should be 15 to 20 degrees cooler coming out than it is going in.
If it is less than 15 degrees, chances are your problem is low refrigerant. You will need a CFC certified refrigeration tech to add refrigerant or locate the leak.
Aug 21, 2009 | Heating & Cooling
Wet line on ceiling between 2 air vents that runs about 8 feet
I would begin by inspecting and repairing the flashing around each vent. Generally you can use a caulk gun with a tube of roof cement for this quick repair.
May 17, 2009 | Heating & Cooling
The clutch in my 92 Jeep Wrangler suddenly stopped working.
pull the boot back on the master and see if it is wet do the same with the slave
Apr 25, 2009 | 1992 Jeep Wrangler
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
D900 Audio Problem
take it and have it check the speaker may need to be replaced
Apr 11, 2008 | Samsung SGH-D900 Cellular Phone
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
