Question about GE Heating & Cooling
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the unit is turned on, the fan sticks. Can anyone assist me with a DIY type fix until I can have it serviced? Fan will not rotate & makes loud buzzing
  • 3 Answers
The condenser fan capacitor has failed. No interim fix - just get a technician!!
Posted on May 17, 2009
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
How old is my Hotpoint dishwasher, model HDA3400G02WW Serial SG8047194 is??? My dishwasher humms, but doesn't runs at ALL. What could be the problem????
The motor is stuck. If you remove the lower cover and see a square aluminum motor it is less than 7 years old. Make sure power is off at breaker and rotate the motor shaft
by turning the fins inside the motor.
If the motor is black and round you have to turn
the fan blade which is located in a slot between the metal pump and the plastic
pump. Also once freed, a light shot of silicone or WD-40 (silicone works better) at the
bearing ends. Also check pump for leaks around the drain solenoid (shiny shaft attached
to a plastic triangle). If it's leaking during pumpout, the seal has failed. The pump runs
around 100 dollars typically. Hope this helps.
May 30, 2011 | Hotpoint 24 in. HDA3400G Built-in...
When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
Motor humms but blades do not rotate
Try replacing the capacitor which is the cheaper option (about $20) if still don't work replace the motor.
Jul 31, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the...
I think this is a double problem post,so I will answer the top first.
The fan capacitor may be bad or the motor it's self is seizing up and will need replaced.
Second portion of post:
  1. Brown and brown/white go to the new capacitor(If you didn't get a new one with the motor,You will need to)Should be 7.5 mfd
  2. Black To the contactor where the black was originally connected
  3. yellow to the contactor where the red was originally connected
May 06, 2009 | Heating & Cooling
Defrost Cycle Problems
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
