Question about Lisette L Clothing
Location in Australia to purchase Lisette pants
People search australia
Contact the Flying Doctor Service direct ?
Jan 06, 2014 | Sewing Machines
Is there a difference between pants and trousers in Australia? I am visiting there and trying to shop and getting confused.
Australia is known to differentiate between pants and trousers. shorts are similar to trousers, but with legs that come down only to around the area of the knee, higher or lower than the knee depending on the style of the garment. (wikipedia)
Feb 28, 2013 | Clothing
Are pants tighter when you first buy them?
Yes new pants are usually tighter and they will stretch out when you wear them. I usually find that they return to their normal size once they've been washed but over time they do tend to stretch.
Jan 14, 2013 | Clothing
I have just purchased a Garmin 1390 GPS with both NZ & Australian mapping, I am going to Oz today and donot know how to access the Australian maps, it just starts with NZ ones.
Press TOOLS (the spanner symbol)
Press SETTINGS (the spanner symbol) or LOCALE on some models
Press MAPS
There will be a tick beside whatever maps are selected. If the Australian map is not selected press the map name and it will be selected.
When you go to Australia the satellites should automatically pick up your location and load the correct map. If not or if you want to save an Australian location in favoutites before you go;
Press WHERE TO
When the screen comes up to enter the address you'll see NZ as the country selected
At the bottom of the screen you'll see an item CHANGE COUNTRY
Press this and you can select Australia
This should bring up the map of Australia and you can enter addresses there.
Dec 19, 2010 | Garmin nuvi 1390T Car GPS Receiver
Will my irish garmin 250 work in australia
Your GPS will require a map set for Australia to display your location on the screen. You have several medium choices for street level map of Australia.. you can purchase your choice of an instant download, purchase CD ROM or an SD memory card version to install / load on your GPS. The link above will help you choose which works best for you.
I hope this helps!
Nov 22, 2010 | Garmin GPS
Purchases a makita compound sa wUSA can i use it in AUStralia
The only obvious problem is that a saw purchased in USA will have a 110 volt motor. Mains voltage in Australia is 220, so you would need to purchase a transformer in Australia to step the voltage down to 110.
Dec 29, 2009 | Makita 10" Dual Bevel Sliding Compound...
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
Clothing Logo
99 people viewed this question
Top Lisette L Clothing Experts
Erin Wood
Erin Wood
ray gallant
Da Doc
Are you a Lisette L Clothing Expert? Answer questions, earn points and help others
